I have a computer its config is as follows
[CPU-Z Report
CPU-Z version 1.21.
CPU(s)
Number of CPUs 1
Code Name Willamette
Specification Intel(R) Pentium(R) 4 CPU 1.70GHz
Family / Model / Stepping F 1 2
Extended Family / Model 0 0
Brand ID 8
Package mPGA-478
Core Stepping D0
Technology 0.18 µ
Supported Instructions Sets MMX, SSE, SSE2
CPU Clock Speed 1716.9 MHz
Clock multiplier x 17.0
Front Side Bus Frequency 101.0 MHz
Bus Speed 404.0 MHz
L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 256 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 1716.9 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
Mainboard and chipset
Motherboard model P4M266-8233,
BIOS vendor Phoenix Technologies, LTD
BIOS revision 6.00 PG
BIOS release date 03/19/2003
Chipset VIA P4M266 (VT8751) rev. 0
Southbridge VIA VT8233A rev. 0
Sensor chip Winbond W83697HF
AGP Status enabled, rev. 2.0
AGP Data Transfert Rate 4x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 64 MBytes
Memory
DRAM Type SDRAM
DRAM Size 256 MBytes
DRAM Frequency 134.3 MHz
FSB
RAM FSB + 33 MHz
DRAM Interleave none
CAS# Latency 3.0 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 6 clocks
# of memory modules 2
Module 0 Micron Technology SDRAM PC133 - 128 MBytes
Module 1 SDRAM PC133 - 128 MBytes
Software
Windows version Microsoft Windows XP Workstation Service Pack 1 (Build 2600)
I have NVIDIA GeForce 4 MX 440 AGP8X Graphics card. I installed DRIV3R but after launching the game it refuses to start & does not disply cause. Tell me what to do?[/quote]
