Old 05-09-2004, 07:18 PM   #1 (permalink)
Default DVD cloning
hey guys
i got a couple of dvds from a friend and created an image using nero
the problem is these are 8 gb + dvd's
i bought a 4.7 gb dvd by mistake ..
my question is what kinda dvd should i buy to make this work ?
i do not have a dual layered writer .. i have one that came along with my laptop ...
i did see the 8gb+ dvd's but i dun remember if that was dual layered or what
i just needed to confirm before i went out and bought another blank dvd
No Mercy, No Limits.
theraven is offline
Old 05-09-2004, 08:27 PM   #2 (permalink)
To copy the whole DVD movie disc as it is u will need a DVD 9 or a DVD with 8.7G capacity. Or else u can use a software like DVD Shrink to shrink the movie to fit on a 4.Gb dvd. Best thing to do would be to keep the movie as it is and get rid of the extras like ads, trailors, making, extra languages etc. Also you can get rid of 2.1 track and keep the 5.1 or vice-versa. Even after doing so ur movie doesnt fit then u'll have to transcode it. Hope this is what ur were looking for .......
And yes that 8+ DVD recordable that u saw shud be a DL one.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 05-09-2004, 08:47 PM   #3 (permalink)
Default right said
i also agree blade_runner..even though i use to make avi's [using Dr.divX]
to fit any size dvd to a single cd with some tweaking with audio and video codecs and without any significant loss [or should i say no visible or audible loss]
AND TO ADD "NICE AVTAAR BLADE_RUNNER" my fav. movie it is..!!
__...:::---*Keyboard Cowboy*---:::...__
whistler is offline
Old 05-09-2004, 08:57 PM   #4 (permalink)
it should be dual layered ?????
so i guess that wont work on my dvd writer will it ??
theraven is offline
Old 05-09-2004, 08:58 PM   #5 (permalink)
whistler .. i need to write dvd's not cd's
theraven is offline
Old 05-09-2004, 09:25 PM   #6 (permalink)
o and blade ... i need to keep the first 5 tracks of the dvd ... it has 5 movies in it .. it has 20 tracks of some crap
and i have its image in nero .. so if u could help with that that would be gr8
tho i doubt with 5 movies .. removin the excess will make any diff
apart from this .. i have a couple of dvd rips ... the vob files
i will do a search also .. but it will help if anyone can suggest how to convert that back into a dvd
theraven is offline
Old 05-09-2004, 09:40 PM   #7 (permalink)
Default No offence..just an idea..
raven, its just that what i do....that dosent mean i want u also to do it.
and read between the lines-----
its ur choice as what u would like to do.
as for the vob files.....check this
http://www.avi-vcd.com/
again no offence meant...
whistler is offline
Old 05-09-2004, 10:16 PM   #8 (permalink)
Ahh ! So its one of those multi movies compilation. In that case the only possible thing one can do is to back up say 2 to 3 Movies per disc......Otherwise it wudnt be possible ! No need of DL discs man ....
@whistler: Yep its my fav movie too and that my fav character frm the movie ! And dude as much as we all appreciate ur helping spirit raven wants to back-up his dvds in dvd video format, so avi format is kinda not wanted here. Hope u get the point.
Old 05-09-2004, 10:32 PM   #9 (permalink)
Default ok..
@ blade: okgot the point..
whistler is offline
Old 05-09-2004, 10:43 PM   #10 (permalink)
Default oh ok
that nrg reminds me....that there is a plug in of nero named DVD MPEG-2..
that might help..
do a google or PM me..
whistler is offline
Old 05-09-2004, 11:01 PM   #11 (permalink)
Default check this out..
check this for ur vob to dvd conversion
http://www.dvdsanta.com/
http://www.convertzone.com/net/cz-dv...-dvd.htm#About
whistler is offline
Old 06-09-2004, 12:31 AM   #12 (permalink)
hey thanx whistler ... and blade ...
i guess thats what i gotta do then
thanx for the help guys
theraven is offline
Old 06-09-2004, 12:49 AM   #13 (permalink)
Default thatz ok
felt good to help u..
no probs m8..
one thing i would like u to comment upon..
http://www.dvdidle.com/products.htm
whistler is offline
Old 06-09-2004, 01:03 PM   #14 (permalink)
yeah dvd idle pro is a good software
never got down to using it tho...
i wanted to use it for the region free function ..
i was using using dvd region free till now ..
u dont need the dvd pack
there is a very good dvd rip/copy software called super dvd or something and its free
players the best is windvd
theraven is offline
Old 06-09-2004, 07:57 PM   #15 (permalink)
yeah but installing windvd, then dvd region free, after that super dvd ripper..i think super pack is much reasonable to be all in one..[besides Dr divX which is a must]
ur turn...
whistler is offline
Old 07-09-2004, 03:24 AM   #16 (permalink)
lol
this aint an argument .. so its not abt turns
yes u are right ... it is easier this way
but its just abt the tools anyone is comfortable with ...
and i seem to be comfortable with these for quite sometime ... since before i heard abt dvd idle pro and the pack ...
so its kinda hard to shift tools thats all
theraven is offline
