Old 07-01-2009, 12:23 PM   #1 (permalink)
Question Need help transferring blog
I run a Blogger blog, which i am planning to transfer to an external host and use Wordpress instead? How can i route my visitors to a new blog if they are visiting my Blogger blog? Need i do something to my Blogger blog?
Also, what measures do i have to take for transfer?
Rishi87 is offline
Old 07-01-2009, 01:13 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: Need help transferring blog
I can help you with the Transfer thing. First of all take a good paid webhost. Check list here of some wonderful webhosts here: http://mrintech.com/a-guide-for-sele...sting-services
Now install Wordpress there.
After this Go to Manage Tab and then Import. There is an easy import option for Blogger post.
Now with redirection problem, i don't know much about redirection, so other Digitians will help you
- MrinTech :)
mrintech is offline
Old 07-01-2009, 02:14 PM   #3 (permalink)
Question Re: Need help transferring blog
Thanks for the help buddy. Will i lost the formatting and images of my posts if i import it to Wordpress?
Rishi87 is offline
Old 07-01-2009, 03:16 PM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
NO. Give the address of your blog lemme see it
- MrinTech :)
mrintech is offline
Old 07-01-2009, 03:49 PM   #5 (permalink)
tHe nEw gEEk......ITian
pr.itdude's Avatar
if u want only redirection........
then a simple javascript may help u.......
pr.itdude is offline
Old 07-01-2009, 04:18 PM   #6 (permalink)
Here you go buddy, http://techvigator.blogspot.com/
Oh no, do i have to go through such scary looking things? Anyway, is there any script available online?
Rishi87 is offline
Old 07-01-2009, 06:04 PM   #7 (permalink)
Wise Old Mouse
mrintech's Avatar
No you will loose nothing. First of all go for a paid host and import all your posts via wordpress. Before taking paid host ask them how to redirect your old blogger posts to new domain posts
cheers!!
- MrinTech :)
mrintech is offline
Old 07-01-2009, 06:51 PM   #8 (permalink)
The Unknown's Avatar
@Rishi87, here's your script -
<script type=text/javascript>
window.location='http://yourblogaddress.com'
</script>
This will redirect any visitors of your blogger blog to yourblogaddress.com
Post based redirection requires more coding and also URL compatibility on the Wordpress site i.e. a specific type of pattern which is easy to implement.
KDE on ArchLinux
The Unknown is offline
Old 07-01-2009, 07:55 PM   #9 (permalink)
Wise Old Mouse
mrintech's Avatar
Great Didn't Knew This. Thanks
- MrinTech :)
mrintech is offline
Old 07-01-2009, 09:58 PM   #10 (permalink)
pr.itdude's Avatar
hmm.......gr8....!!
Need some help in transferring fund axxo QnA (read only) 2 04-02-2008 10:48 PM
SUGGESTION: Best Blog Site for Starting a Blog Vishal Gupta QnA (read only) 43 20-09-2007 08:59 PM
Transferring apps from one mmc to another hemant_mathur Mobiles and Tablets 10 05-10-2006 10:15 PM
Transferring mails BLITZ~KRIEG! Internet & WWW 4 29-04-2005 02:50 AM
