Old 31-05-2005, 04:01 PM   #1 (permalink)
Default NEED A LITTLE HELP GUYS...
Config main ()
Printf("Guys a simple problem wit my system..");
Win 2k SP4
(All Updates)
Winfast Geforce Fx 6600 (Updated Drivers 66.93 Forceware)
AMD 64 3000+
My system takes atleast 2 to 3 mins to shutdown
No extra programs running in background...
Any tweaks up ur sleeves !!! ???
..::The Slam Team::..
Slam Team is offline
Old 31-05-2005, 04:25 PM   #2 (permalink)
aadipa's Avatar
Defrag
Make large amount of free space on your system drive
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 31-05-2005, 05:09 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
can u tell me where is ur page file located?? & what is its size??
how big HDD & how many partition do u have?? do u have??
if possible then pls post ur msconfig start up menu screen shot....
(P.S. as many of us use the dial up so pls give a thmbnail or a link to that pict)....
Choto Cheeta is offline
Old 01-06-2005, 11:55 AM   #4 (permalink)
club_pranay's Avatar
i also suggest a scan disk..
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 01-06-2005, 12:40 PM   #5 (permalink)
Rebooting
i still think his page file is too big & may be on the same partition as the windows....
Old 02-06-2005, 06:13 PM   #6 (permalink)
I had a similar problem after installing Microsoft .Net v2.0
Fixed after uninstalling and going back to previous version.
Keith
Keith Sebastian is offline
Old 09-06-2005, 12:31 PM   #7 (permalink)
CCIE# 20863
Upgrade 2 winXP.
or u can try reducing 'default wait before killing not responding program' time using any tweaking tools for win2k.
Bugs can neither be created nor be removed from software by a developer. They can only be converted from one form to another. The total number of bugs in the software always remain constant.
theKonqueror is offline
Old 09-06-2005, 10:40 PM   #8 (permalink)
Rebooting
hummm.... 8 day has past.... still no answer from the original author...
Old 09-06-2005, 11:31 PM   #9 (permalink)
NikhilVerma's Avatar
Does your system has an option to "Clear Page File before Shoutown" ???
Download SafeXP to remove the option
NikhilVerma is offline
Old 10-06-2005, 01:37 AM   #10 (permalink)
SABER RIDER
maverickrohan's Avatar
hey.........even i have a similar problem but its not as severe..............
normally my system shuts down in 5-15 seconds but at times(very random) it takes 30 seconds......
WinXPSP2 on AthlonXP 1800+
The problem started after i started using shutdown features in softwares like DAP, VirtualDub, #1 DVD Ripper, CustomizerXP, LeechGet 2004..........
What happens is...............There r many processes running on ur system............so while shutdown some of them OR one of them does not respond while Shut down..........Windows has a default wait time set, in XP it is 20 seconds............for non responding apps. ............ so even though there is no IDE activity still itl take a long time to shutdown...
Page File size cud b one reason but usually its cos of non responding apps n processes:
How to figure that out?
Well all the time during shutdown if ur comp shows the IDE(red light) glowing/blinking...its gotta do with ur HDD n pagefile performance.........
If at some stage during shutdown for quite some time if ur IDE light is OFF it means its due to non responding processes...!!!
u can use Advanced System Optimizer to tweak ur system n change these settings (www.systweak.com)
but wid me the prob still persists(randomly)
but::
normal = 5-15 secs
slow = 30-40 secs
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 15-06-2005, 01:30 PM   #11 (permalink)
Arey guys thxx for the replies... my exams were goin on.. so I couldn't login for a few days...
Anyway I tried the S/w in this month's digit ( I guess the software's name was power defrag) and it does the defragmenting fast.. Then i did the Speed Disk from the Norton Systemworks 2005 ... Everything over... but still this f***in damn thing doesn't shutdown properly.. Always ...damn.. and btw win 2k doesn't have msconfig... have to remove extra things from registry only...
Old 15-06-2005, 01:32 PM   #12 (permalink)
Ya ya.. my system has one and only one C Drive and my pagefile is of 1280 Megs LOL.. Is that da problem... does windows flush it everytime it shuts down...???
Old 16-06-2005, 05:29 AM   #13 (permalink)
Fresh Stock Since 2005
Critical Errors Found....
Can't Continue...
_khAttAm_ found many critical errors and is Sending Error Report to ThinkDigit Moderators
The Details of the error is given Below:
Error in Module 1
Wrong Section...
BTW, What software is being reviewed in here??
Solution: Post in the right sections of the forum.
Error in Module 2
Three posts in a row...
Solution: Use the [edit] Option to edit your previous posts and add to the previous posts. Don't just post a reply again and again and yet again...
Investigating on the original problem
Problem(s) Found:
Possible Problem: Pagefile Size too Large.
Solution: Try limitting the Pagefile size. You'll never need a pagefile larger than 2.5 times the RAM coz if your system even does, it will hang...
http://www.khattam.info
khattam_ is offline
