help me - machine hanging like hell - vendor help less
first
machine specs , as per to details by sisoftsandra 2005 plus my comments
Processor -> 1x intel (R) Pentium (r) 4 CPU 2.40Ghz
l2 on-board cache - 1mb , ECC sycronous , ATC , 8-way set , 64 line size , 2 lines per sector
microcode -> MUoF330B
In Nehru place terms pIV 2.4 prescott
Motherboard
Gigabyte Technology Co. Ltd
8I845GERZ
or Gigabyte D845GE-Premium as known at Nehru Place
FSB - > 4*134 Mhz
Total memory ->
512DDR
OS -> Ms Windows Xp/2002 Pro. (win32 X86) 5.01.2600 (
Service pack 2)
general work done on machine
1->
Adobe Photoshop /Corel draw work from College/Institute
2-> General net surfing /messengers / emails
3->
Listening to Music from Raga / smashits sites
Softwares installed for security
Nortan Internet Security , Norton Anivirus , Ms Antispyware Beta
The problem ->
Machine random hang.... most of the times a hard reset machine boots fine but hangs again with in 15 minutes. let the machine off for 15 minutes and boot the machine. machine more stable (wont hang in 15 minutes but will hang later on as per to its wish).
Usually if i boot the machine and do not work on it. it wont hang even after 3hours.. some times gives cool 3-4hrs of working troublelessly. but most of the time you do some Heavy work (say 1/2 - 1hour on photoshop while listening to music online) it Simply hangs
Already done/checked ->
1-> Replaced the systems RAM with other working one from my other comp... the problem persist
2-> run MemTest86 for around 45minutes... no error detected
3-> Checked CPU temperature just after Hang from Bios it is below 50C
4-> Formatted machine over 5 times , with 2/3 different OS CDs , problem persists
5-> No entry of Hang/Crash what so ever in event viewr
Vendor solution
1-> Machine did not hanged in 2 days.. was on for most of the time
2-> Try disabling Processor cache from BIOS. (i was not able to do so, as no such option in BIOS)
3-> Do not install intel Application Accelerator.. I stopped installing that from Driver CD
4-> As a test only he asked me not to install norton Antivirus, it changes/currupts a few required files which might hanging your computer ... I did not installed antivirus/NIS during last format and the machine hanged the very same day
5-> He tried to change the PS once with a repaired PS that he had.. the machine hanged during the driver installation of that format.. on that he said it might be because of faulty PS as it was a repaired one.......
Please advice me how to go about now.... of the 2 months of ownership this machine was switched off in my house for 3 weeks and has spent 2 weeks at Nehru Place but no avail.
What could be fault in the machine.
my suspect in decreasing order -> motherboard / CHIP , PS , Heat
You know the Guys at Nehru Place how to get the stuff going..???
