31-05-2005, 02:45 PM
Maxthon 1.3.1 released
Change log
v1.3.1 [2005-05-31]
+ New RSS notify popup.
+ New appreciation service - favorite service.
* Do not change focus away from address bar when inputing addresses.
+ 'Open offline' to start dialog.
+ Advanced option: Do not auto-refresh current tab.
+ Do not need confirmation when existing Maxthon, if only 1 blank page is opened.
* Click on status bar IP address pane to copy the ip to clipboard.
Download from here : http://www.maxthon.com/download.htm
Source Maxthon Forum
1 aadi + 1 aadi = 1 full ;)
31-05-2005, 04:25 PM
If you dont mind can you let me know the advantages of using this browser over Firefox, have been hearing a lot about this and was wondering wether to try it out.
Thanks
Quote by Garfield'
31-05-2005, 04:31 PM
It is worth a try!!!
It comparable with opera and firefox and very fast too. i am using it now and i have also used opera and firefox.
31-05-2005, 04:38 PM
I hope it can be uninstalled if i don't want it without any problems!!
Quote by Garfield'
31-05-2005, 07:43 PM
Distinguished Member
Thanks
DONT THINK, GO AHEAD ! you will love it and all its amazingly useful features ! i have tried avant, firefox too, but MAXTHON is the best one, i think ! wont have any problems. apart from tabbed browsing, it got lotsa other features like skins,re-opening closed pages, fast loading, accessing other programs from it, ofcourse sevral search bars, RSS feed, pop-up/ad/active-x/flash blockers & a history & cache eraser.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
01-06-2005, 02:59 PM
i dont think you will uninstall it at all
Anyway you can uninstall it without any problem.
It gives upto 13.3 kBps speed on my 56kbps connection. Even opera cant do that!!! 8)
02-06-2005, 01:14 AM
In maxthon, earlier whenever i (shift-click) the link, the link used to open in new tab without going to that tab.
Now after few updates, whenever I (shift-click) the link, the focus goes to the new tab. This I don't like as I may have to open multiple links remaining in the same page.
How can I solve my problem? any help
[ॐ एसएमएस॰सोल्भर ॐ]
02-06-2005, 02:08 AM
Coming back to life ..
Just Disable Activate New tab as this :
Options > Maxthon Options > Tab
Click on New Tab
Uncheck Activate New Tab option ..
You are done ... You can also enable disable it by clicking on the concerned button on the statusbar (3rd from right, just next to Enable Disable All filters button) ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
02-06-2005, 02:10 AM
And btw.. Instead of clicking Shift Click every time, just enable Open in New Tab button or Middle Click on links ..
Open in New tab is the Sunstyled button on the statusbar (2nd from right, just next to Simple Collector) ..
02-06-2005, 09:37 AM
maxthon is just gr8 , the ad blocker is just fabulous. i havent seen anything as useful as that.The only disadvantage is whenever i go to a cra** website, it just wont open.
and it is heavily light on my memory.and loads 10 times faster than FIREFOX!
"Try again, fail again, fail better" - Samuel Beckett
03-06-2005, 12:27 PM
thanks for the info, I've updated Maxthon to the latest version.
03-06-2005, 04:05 PM
Just Do It
I'd downloaded this software from majorgeeks.com, MYIE2[HOT] which says that its more faster and uses less system resources. Is it really true, also does it have JAVA in it.
BTW it didnt work on my sys.
03-06-2005, 05:06 PM
Maxthon is just a shell for IE, giving more powerful interface to IE with tabs, and blocking some known problems of IE.
Maxthon don't have JAVA in it. You need to install Java Runtime Environment (JRE) and Java Plugin for IE (which gets installed with JRE) just like Java plugin for Mozilla.
And now it has also featured in The 100 Best Products of 2005 by PCWorld (More about software list)
13-06-2005, 04:29 AM
@aadipa: i like maxthon but here is where it comes down to opera:
when we use the back button opera loads from the cache: -so this not only loads faster but also saves ur download limit(if any)
i am not saying that maxthon doesnt load from cache, but if say i am surfing 3 websites(3 tabs open) at a time ,then when i press back button it does of the same tab from cache
but when i switch tabs ,it loads from the url
13-06-2005, 01:43 PM
Just Do It
Since u mentioned abt Java gimme a link for the download .... The one I installed says class not registered...
Cheers
13-06-2005, 02:50 PM
14-06-2005, 12:59 AM
Just press BackSpace key ..It will load from cache ..
btw .. I use Keyb more than mouse .. so got used to it ..
14-06-2005, 01:20 AM
no batty u didnt get it "exactly"
see if i have opened 3 -4 tabs and i keep juming from one tab to another, then the backspace button "not always" loads from the cache.
sometimes it does(and mostly when its in the present tab )
.so wat happens is i just open 1 tab .
thats it.
its not all that a problem, but man waiting for the page to load that u just visited is "getting on nerves" sort of thing!!
14-06-2005, 01:59 AM
#19 (permalink)
Gee ... It works fine here
14-06-2005, 02:07 AM
#20 (permalink)
but batty tell me how o change cache settings then?
it might work here too.
14-06-2005, 04:35 AM
#21 (permalink)
Fresh Stock Since 2005
Maxthon doesn't have adblock extension, does it??
Thats why I don't use anything else, but FireFox...
http://www.khattam.info
14-06-2005, 05:10 AM
#22 (permalink)
maxthon has a gr8 adblock feature!!
14-06-2005, 10:40 AM
#23 (permalink)
Yeah Maxthon don't have adblock extension.
But it have very good Ad Hunter built right into it, so no need of extension
See
As you can see, it is one of the most advanced ad hunter.
Best thing is that you can easily block selected image from loading, while loading others, like i have blocked digit logo from the forum page
17-06-2005, 02:58 PM
#24 (permalink)
Just Do It
I downloaded 1.5 but doesnt integrate wit Maxthon ..... Why ??
17-06-2005, 04:17 PM
#25 (permalink)
If you installed and integrated with IE, it is all that is needed coz Maxthon runs above IE engine.
Check if you have given option in Advanced Tab of Internet Options......
17-06-2005, 07:10 PM
#26 (permalink)
Just Do It
@ Adipa - Yes, but still doesnt work.
17-06-2005, 09:30 PM
#27 (permalink)
Then check if you disabled this ?
18-06-2005, 12:18 PM
#28 (permalink)
Just Do It
@Adipa - No thats not disbaled
Search this Thread |
