Old 06-01-2009, 10:07 AM   #1 (permalink)
True Techie
nithinks's Avatar
Exclamation Urgent:Pen Drive Currupted
Hi,
I have Transcend JetFlash 4GB pen drive, Today when I plugged in, there was "0 bytes" of total available space and the file format was unknown.
I tried to format the drive, but no use.
I tried with the recovery software supplied by transcend, but it did not work.
When I try to create a file , or try to format it, I get a error "Insert a disk into drive E:\"
So.. anybody can help me with this issue?
Thanks
http://www.mytechyard.com/
nithinks is offline
Old 06-01-2009, 10:32 AM   #2 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: Urgent:Pen Drive Currupted
Jst Give It To Replace
VarDOS is offline
Old 07-01-2009, 02:16 AM   #3 (permalink)
ztbryan's Avatar
I recommend u check your USB ports carefully, if not it's probably defective
ztbryan is offline
Old 07-01-2009, 09:01 AM   #4 (permalink)
True Techie
nithinks's Avatar
No.. I actually checked in 2 different machines..
nithinks is offline
Partitions Currupted .. Urgent Help needed ! Dark Star Open Source 16 26-05-2008 09:15 AM
URGENT : my c drive eating space ? shreyadr QnA (read only) 7 23-01-2008 06:47 PM
Currupted Nokia Pc suite hullap Software Q&A 2 07-02-2007 08:03 PM
XP profile currupted :( help ! vijaythefool Software Q&A 2 20-11-2004 07:30 PM
Help Badely Needed.......My Xp is currupted... saROMan Software Q&A 16 03-10-2004 03:03 PM
