Old 04-01-2009, 04:49 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default dvd riting woes ! ! !
i have a plextor dvd ritter ... working nice ..... wanna write a [4.4gb] dvd in NERO 8, whot speed & size should it b written ??? coz tried 2 rite a dvd with 4.18gb with 12x speed >>> it showed me power callibration error ...
... W H O T ...
ax3 is offline
Old 04-01-2009, 07:48 PM   #2 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Default Re: dvd riting woes ! ! !
Writing 4.4gb can be a bit troublesome.. 4.18gb isn't any problem..
The possible reason for error could be background processess..There could be other reason..
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 04-01-2009, 10:02 PM   #3 (permalink)
Power calibration error is due to dirty lens.
Use DVD lens cleaner, it should solve your problem.
neogen is offline
Old 04-01-2009, 10:07 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
@OP
It's writing & riting.
And 4.4GB is not possible, i think so.
Blogging at:
Technostarry
saqib_khan is offline
Old 04-01-2009, 10:57 PM   #5 (permalink)
Originally Posted by saqib_khan View Post
@OP
Wrong!!
You can burn as much as 4483MB of data without any problem whatsoever.
neogen is offline
Old 05-01-2009, 11:17 AM   #6 (permalink)
ax3
ax3's Avatar
i did disable many processess in bg [antivirus,firewall,ssaver etc] .....
@ whot speed, max or min ???
r mosaer b dvd good 1`s ??
& some say, "burning @ low speed is good ie readable by all drives" is it true ??
... W H O T ...
ax3 is offline
Old 05-01-2009, 11:26 AM   #7 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: dvd riting woes ! ! !
I guess max dat supported by a blank DVD is 4384 MB. If u go for overburn then it supports to 4400 or 4500MB.
Does d media u r trying to burn, supports 12X writing? If yes write at the speed of 8-10x.
Some links:-
http://www.osta.org/technology/dvdqa/dvdqa4.htm
http://www.feurio.com/English/faq/fa...er_speed.shtml
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 05-01-2009, 01:50 PM   #8 (permalink)
Some links:-
No, as I said you can burn precisely 4483MB of data on DVD without any problem, anything beyond this limit will cause trouble.
@ ax3, did you ignore my previous reply?
Yes, burning at low speed yields reliable media, 8X is best bet!! And since your DVD lens is dirty(power calibration error) you can not burn at high speed, it will automatically switch you to low speed.
neogen is offline
Old 05-01-2009, 04:52 PM   #9 (permalink)
ax3
ax3's Avatar
@neogen .... 4483MB of data on dvd, it will rite bt wont b recognizable ...
its not switching 2 lower speed [8x,6x, ..] either .......
bt rites on dvd+rw with multisession also ..........
will check with diff media [say sony] ......
... W H O T ...
ax3 is offline
Old 07-01-2009, 05:18 PM   #10 (permalink)
ax3
ax3's Avatar
Sony dvd media is working 4 me .......
bt time taken was 2 much >>> 1 hr 20 min ........
... W H O T ...
ax3 is offline
Old 11-01-2009, 01:11 PM   #11 (permalink)
ax3
ax3's Avatar
checked nero info tools & it says "system ASPI" is missing ..... whot 2 do ???
... W H O T ...
ax3 is offline
RAM woes. HELP!! Arun the Gr8 Hardware Q&A 1 15-12-2007 11:40 PM
LCD woes assasin Hardware Q&A 2 09-06-2007 02:47 PM
IE 7 Woes Bruce_Wayne Software Q&A 5 11-04-2006 03:09 AM
Suggest DVD movie riting soft . . . . sagargv QnA (read only) 3 24-03-2006 09:29 AM
USB woes !!!! mohit Peripherals 5 27-05-2005 11:45 AM
