hi.. digen... so far so good.... ur solution is working... but i havent cheaked it with every program though.... but it works with IE....
but as all will say porxy slows down.... it did also... but i dont care as long its work for me....
thnx for the help, replys & the solution....
i hope if i need any help from u in the future u will help me out....
& keep this topic going.... if any one can give other solution....
& digen... i have a nother question... as this topic is for anymous useing thats why i amnot writing a new topic....
is it ligal to send anonymous email through command promt.... recently i found this on a forum.... though i dont know whether its ligal or not.....
here it is....
I have edited i as some one might use it for bad....
though its not totaly anonymous as in the 2nd stape when u say helo ur ip gets loged.... as i am with Static ip so its alwasy same.... tor wasnt able to bypass this.....
Edited
bqz of security resion....
