Old 05-09-2004, 04:41 PM   #1 (permalink)
Default this sytem?
ok here's the thing, i want to get this system, at the moment i don't have a limit on how much i can spend.
my question is which one of these parts is available in india, and if so, for how much?
AMD 64 FX-53 (socket 939)
MSI Neo2 Platnium mobo
160 gig minimum hd 7200rpm (would prefer seagate)
ATi Radeon X600pro (256mb)
if the FX-53 isn't avialable, is the Athlon 3800+?
TIA
acp89 is offline
Old 05-09-2004, 07:11 PM   #2 (permalink)
939 ull just have to look a lil ... or maybe ask the dealer to order it
no one will be stockin it ... well hardly ..
everything else ull get here
ive not heard of the athlon 3800+ .. so im not sure
anyways ull get 64 bit processors easily ..
for the x600 u can contact asustek directly
btw this is a pci-express version .. and since i havent looked it up .. i dunno if amd mobos .. even the 939 chipset .. supports pci-express yet ..
so just look into all this before u buy ..
cheers ...
No Mercy, No Limits.
theraven is offline
Old 05-09-2004, 07:13 PM   #3 (permalink)
o sorry forgot abt the prices ... the x600 PCI-e version is available for arf 17k
if u have an 8x board u can go for the 9800 pro for 14k .... the x800's etc cross into 20k's
160gb 7200 rpm sata drive ... 5400
pata drive 4900
not sure abt the mobo and processor. .. tho mobo will cost u upwards of 8k
theraven is offline
Old 05-09-2004, 08:35 PM   #4 (permalink)
wait for the NF4 and go for a PCI 6800 ultra wid a 3800+.
nikhilesh is offline
Old 05-09-2004, 08:38 PM   #5 (permalink)
edit:i mean PCI-E 6800ultra,do wait for the N-Force4 but
Old 05-09-2004, 08:55 PM   #6 (permalink)
does the x600 come only as pci-e cause i thought it was agp compatible too?
nobody know any prices of the 3800+ or the fx53?
edit: if the amd boards aren't compatible - is it worth getting the intel p4 3.6?
acp89 is offline
Old 05-09-2004, 10:19 PM   #7 (permalink)
You might get the Athlon 3800+ just inquire @ vendors who stock hi-end stuff. x600 is not a good card, rather go for a 9800XT or if u can raise ur budget go for a 6800GT, which is the best bang for the buck !
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 12-09-2004, 04:29 PM   #8 (permalink)
what's wrong wid the x600?? i want a mid-range card smthn that's better than the GeForce 4 MX 440 that i've got now...
and i'm prob gonna opt for p4 3.6 cause i can't wait for nforce 4 to come out and i need PCI-E
acp89 is offline
Old 12-09-2004, 05:40 PM   #9 (permalink)
nuthing is wrong with the x600
it performs something like the 9600
i think blade was only try to suggest u a better card for ur buck thats abt it
after that its ur choice
theraven is offline
