Old 03-01-2009, 10:26 PM   #1 (permalink)
Default Li-Ion Battery
I short circuited the the terminals of a Li-Ion Battery(Camera Battery). Nothing happened like high temperatures of heat generation. But my battery stopped working after that. It was previously charged almost fully before the short circuit.
Please let me know what happened to my battery. Have I screwed my battery?
hariharan is offline
Old 04-01-2009, 08:53 AM   #2 (permalink)
Section Moderator
gopi_vbboy's Avatar
Default Re: Li-Ion Battery
Get a new battery...i think u spoiled it.........Why do u do that when its said dont SHORT CIRCUIT
Get it done from original vendor.....dont go for duplicate ones
gopi_vbboy is offline
Old 04-01-2009, 11:17 AM   #3 (permalink)
I had to short circuit because even though the battery was fully charged i was not able to switch on the camera.... i thought short circuit might discharge the battery.. isn't it?
Old 04-01-2009, 12:14 PM   #4 (permalink)
Chetan1991's Avatar
Arrow Re: Li-Ion Battery
No man. Short circuiting doesn't discharges the baterry but may render it useless. The only way out for you is to buy a new battery, I think that one is useless now. And Remember, to discharge a battery, you have to put some load across its terminals(i.e. connect something like a bulb, motor or other such device), not just join them!!
Chetan1991 is offline
Old 04-01-2009, 12:30 PM   #5 (permalink)
Hmmm.. bad luck... thanks..
now will have to shell out for a new battery i guess...
is there any way of bringing the short circuited battery back to life.. i mean giving it in a service center or something...
Old 16-01-2009, 10:04 AM   #6 (permalink)
Short circuit you li-ion battery for a very short time could take no problem but a long short curcuit will do great harm to your camera battery.
Go some camera battery shop to buy one. No other ways
greenpower is offline
Old 16-01-2009, 01:53 PM   #7 (permalink)
Hmm.. got a new one...
ups battery gone, how much does 600va battery cost? fallin_a Hardware Q&A 7 14-01-2008 01:28 PM
Is battery down..?? deepakg QnA (read only) 4 12-08-2007 10:46 AM
UPS Battery or new UPS ambandla Hardware Q&A 9 18-02-2007 02:34 PM
