Old 03-01-2009, 09:33 PM   #1 (permalink)
Default Problem, Please Help
Recently my PC was attacked by virus and since I had no other way I opted for formatting my hard drive. Now I have reinstalled XP with SP2. Now the problem is that after the installation of SP2 my USB port does not work, I tried 'Help & Support' center but that was in vain. The problem gets resolved as soon as SP2 is uninstalled. Please help, I want SP2 with USB port on.
gigyaster is offline
Old 03-01-2009, 09:35 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: Problem, Please Help
I think this is a Driver issue. You have to update the drivers via Windows Automatic Update after installing XP SP2
- MrinTech :)
mrintech is offline
Old 03-01-2009, 10:19 PM   #3 (permalink)
^^ok, but m in dial-up, takes a lot of time. Any other alternative??
No, the problem didn't get solved after win updates, wats next??
Old 03-01-2009, 11:07 PM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
Try reinstalling the drivers from the CD that you got with your Mobo.
Else: http://www.google.com/search?hl=en&s...xp+sp2&spell=1
- MrinTech :)
mrintech is offline
Old 03-01-2009, 11:42 PM   #5 (permalink)
DID IT, THANKS, After a lot of tik tak I solved the prob.
Old 05-01-2009, 06:27 PM   #6 (permalink)
Wise Old Mouse
mrintech's Avatar
What you did? Explain... Please
- MrinTech :)
mrintech is offline
Old 06-01-2009, 05:35 PM   #7 (permalink)
Nothing special, went to device manager, there was a "!" mark in USB controllers, clicked it and instructed to reinstall drivers. It prompt for drivers CD and I was done. Working fine now but as I remember I followed the same procedure few days back when I was facing the problem then there was no "!" mark. But afterwards the mark was there, couldn't figure out what actually happened.
Old 06-01-2009, 06:35 PM   #8 (permalink)
Wise Old Mouse
mrintech's Avatar
coool
- MrinTech :)
mrintech is offline
Old 06-01-2009, 08:27 PM   #9 (permalink)
^^ really???
Old 06-01-2009, 09:06 PM   #10 (permalink)
Wise Old Mouse
mrintech's Avatar
Yep! Because I didn't think about re-installing the drivers using Device Manager
Me N00B
- MrinTech :)
mrintech is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
