Old 31-05-2005, 09:27 AM   #1 (permalink)
damnthenet's Avatar
Default HELP! IE BUGS!
Hi Forumers,
Whenever I start my IE, it opens. But when I close it, the window gets closed without any problem, but "IEXPLORER" still resides in my "process" in Windows Task Manager. This causes IE to stop responding when I open and close IE many times as the residing "IEXPLORER(S)" take all my memory in the "Process". Help me to solve this problem.
Thanks for your patient hearing.
Sony Xperia Neo V - Review and Discussion Thread:
http://www.thinkdigit.com/forum/mobi...ml#post1520514
damnthenet is offline
Old 31-05-2005, 08:12 PM   #2 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default some first aid needed
hello this is my second post on forum to fellow forumers
And guess what it is the second time I am playing a helping hand to them.
here is a temporary help that you can do.
first of all when you close IE, be sure that you END "IE" PROCESS from
alt+ctrl+del. do this every time you close and it will work fine.
but as a permanent solution, you must probablly check for viruses and if the problem still prevails reinstall IE and download the patches that microsoft releases. Still better switch on to FIREFOX. It is the best I have used.
your name suggests that you hate-the-net. DO YOU?
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 03-06-2005, 09:00 PM   #3 (permalink)
damnthenet's Avatar
Thanks Vandit for your suggestion.
