Old 30-05-2005, 09:32 PM   #1 (permalink)
expertno.1's Avatar
Default wanna help
hi guys
when i open yahoomail using opera it transfers more than 780 kb and then also not opens
whatz the problem ?
reinstalling opera doesn't solves the problem
i have latest spyware removal tools
i use opera 7.54 and win 98 Fe
anyone know whats going on ?
expertno.1 is offline
Old 30-05-2005, 10:47 PM   #2 (permalink)
mekalodu
iinfi's Avatar
have u tried with other browsers ???
c if ur cookies are enabled !!
mekalodu
iinfi is offline
Old 30-05-2005, 11:45 PM   #3 (permalink)
you may be using a firewall which prevents u from accessing that site.add yahoo.com to ur list of allowed sites in ur firewall.
hsksattish is offline
Old 31-05-2005, 07:42 AM   #4 (permalink)
expertno.1's Avatar
well no firewall at all !
Old 31-05-2005, 07:44 AM   #5 (permalink)
expertno.1's Avatar
Default what?????
other browsers also the same problem
Old 31-05-2005, 11:42 AM   #6 (permalink)
mekalodu
iinfi's Avatar
which net connection are you using??
whats ur OS and system??
if its cablenet/LAN ... c if ur connection settings are proper ..
mekalodu
iinfi is offline
Old 31-05-2005, 12:16 PM   #7 (permalink)
expertno.1's Avatar
Default BTW
i have already mentioned
well GPRS connection
14.4 k
