Old 30-05-2005, 12:37 PM   #1 (permalink)
cooldip10's Avatar
Default Problem while copying a CD
I'm a little bit of hesitating But I wanted to ask how can I Copy an original CD so that I can use it to play that game. Direct copying shows an error. But when the data is copied to the hard disk and then to CD.. the game doesn't start, showing a message "Plaese insert the correct CD ROM and restart the aplication." Please Help.
I think its that cracking criteria..
Game I 'm wanting to copy is HARRY POTTER SS
Everything is Possible
cooldip10 is offline
Old 30-05-2005, 12:52 PM   #2 (permalink)
expertno.1's Avatar
use virtual cd
alcohol 120 %
expertno.1 is offline
Old 30-05-2005, 12:53 PM   #3 (permalink)
trigger's Avatar
hey u cn use virtual cd drive software... here is ur link
http://www.virtualcd-online.com/vcd/...nload.cfm?lg=0
Are you watching closely?
trigger is offline
Old 30-05-2005, 01:42 PM   #4 (permalink)
clone cd
Please do not PM me for details about the product. Ask the questions in the forum itself.
Shipping outside Kerala is a hassle.
Ref : http://thinkdigit.com/forum/showpost.php?p=820996&postcount=53
htnakirs is offline
Old 30-05-2005, 01:44 PM   #5 (permalink)
yup use clone cd
In the keyboard of life, always keep a
finger on the ESC key
shyam911 is offline
Old 30-05-2005, 03:42 PM   #6 (permalink)
Look harry wat u r doing is against forum rules read the forum rules before posting. As for the post its reported.The rules http://www.thinkdigit.com/forum/viewtopic.php?t=13993
vasanth_12345 is offline
Old 30-05-2005, 06:18 PM   #7 (permalink)
spice it up
kapsicum's Avatar
u can even use Nero Image drive
kapsicum is offline
Old 30-05-2005, 07:51 PM   #8 (permalink)
QA Juggler
saROMan's Avatar
well for ur Problem the Only suitable ans is use Alcohol/CloneCD to make Image..Mount it on Alcohol..and forget it..
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 30-05-2005, 09:24 PM   #9 (permalink)
expertno.1's Avatar
Clone cd can be found here
http://www.pcwelt.de/downloads/backu.../brennen/6030/
virtual cd here
www.virtualcd-online.com/ vcd/apps/download/download.cfm?lg=0
alcohol 120 here
www.cdfreaks.com/software/6
wanna more
www.gameburnworld.com/cdprotectionutilities.htm
its enough
Old 30-05-2005, 10:02 PM   #10 (permalink)
q3_abhi's Avatar
Virtual CD
Alcohol
clone CD
Nero image drive
Any 1 of them.
q3_abhi is offline
Old 30-05-2005, 10:53 PM   #11 (permalink)
mekalodu
iinfi's Avatar
copy image to HDD using Nero and then copy the image to ur new disc .....
thats the best way
mekalodu
iinfi is offline
Old 31-05-2005, 06:07 PM   #12 (permalink)
My best Advice !
DoNOt make illegal copies but if you want to use GameJack (Search in google.com). It's ultimate for the purpose.
Satyajit Tambe
archzillanx is offline
Old 31-05-2005, 06:41 PM   #13 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Alcohol 120% is the only software to emulate and make 1:1 copy of all types of available CD-Protections and you can also use Daemon Tools for loading virtual cd's.
Direct copying shows errors because in original games files are locked to physical setors of CD. Making Virtual CD's of original games is not illegal unless you do not pass that to somebody or make a duplicate or crack it.
navjotjsingh is offline
