Old 30-05-2005, 11:18 AM   #1 (permalink)
Default DVD drive not responding
Whenever i insert any dvd movie disk the indicator is on continuously and dvd is not playing at all. moreover my pc gets hanged. In My comuter it is always showing DVD disk.
But if i insert the dvd that is with DIGIT it is playing normally. in this case no problem at all. but normal CD is playing in that dvd rom fine.
I am running windows XP , 256 MB RAM , 40GB HDD, SP 2 , Autopatcher march is installed.
Thanking you.
Suman
itz_suman is offline
Old 30-05-2005, 11:32 AM   #2 (permalink)
Check the region settings. And what DVD SW are you using?.
In the keyboard of life, always keep a
finger on the ESC key
shyam911 is offline
Old 30-05-2005, 02:52 PM   #3 (permalink)
Default mightbe useful tip
better use dvd region free software to play any kind of dvd on your computer
sriram_d is offline
Old 30-05-2005, 04:46 PM   #4 (permalink)
U might b trying to use dvd written wid different speed dan ur dvd rom can play.in dat case u cant play ur dvd.try using region free dvd sf..
What doesn't destroy me, makes me stronger.
jamifahad is offline
