29-12-2008, 05:13 PM
Extendin my lappie's battery life
Hello All,
I have a bought dell laptop 1525(in may) with 9 cell battery. Currently i see drop in battery performance.
I usually plug in power always while working even though it is fully charged.
Is it a reason for drop in battery performance?
Now hw to xtend my battery life?
Thanks in adv!
With rgds,
Ram.
29-12-2008, 05:40 PM
Rapacious eBayer
Re: Extendin my lappie's battery life
Laptops are designed to stop charging the battery after the upper threshold level has been reached, a figure usually between 98% and 100%.
To increase battery life, you might want to create a custom power setting for battery mode that kicks in every time you disconnect the charger, for example: decrease the screen brightness from max. to say 75% or even less, set the CPU speed to adaptive or slow rather than maximum and turn off the monitor after 10 minutes of inactivity. Avoid charging your battery when there's a sufficient charge remaining. In such a case, get the charge down to 5% or thereabouts before reconnecting it to a power outlet.
•Favorite track Of '07: Dash Berlin - Till The Sky Falls Down
•Favorite track Of '08: Emilio Fernandez - Reynosa
•Current favorite track: Blackfeel Wite - On The Down (J-Soul Vocal Mix)
29-12-2008, 05:51 PM
thanks...
29-12-2008, 06:59 PM
Tribal Boy
That is sure one of the reasons for the drop in battery performance. For better performance, the charge-discharge cycle should go correct. I mean charge the laptop battery to 100%. Once it reaches 100%, disconnect the external power and allow the laptop to run on battery. Re-connect to the external power outlet when it reaches about 10%. That is the correct method to do.
30-12-2008, 05:02 PM
IronMan; Ready to Roll...
^ Last time I checked, it was best to keep Lithium Batteries on charge, as and when possible. People say that it's best for Li batteries not to fall below 33% charge at any time..
You sure of what you say? Discharging to a minimum and recharging?
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
30-12-2008, 05:38 PM
Member of Apple Family
That process is called calibration of battery and should be ideally done once a month. Other than that, AFAIK using AC Power on fully charged battery does not have any negative effect on it.
30-12-2008, 05:44 PM
r u sure abt this?
Evil Lives 4ever......
30-12-2008, 07:40 PM
Rapacious eBayer
Originally Posted by evewin89
r u sure abt this?
Think about it. It'd look quite stupid to remove the charger everytime the battery gets to a hundred percent.
30-12-2008, 07:58 PM
Tribal Boy
Have a look - Good Laptop Battery Charging Habits?
Yes, it may 'look' stupid, but when we keep on charging the battery or using the external power all time (not using battery) - it will sure reduce battery life.
30-12-2008, 08:14 PM
The Smaller Bang
nice thread...
nyway, don't batteries have a fixed no. of charge cycles ?
I heard its affected if you keep charger on continuously...
And laptops also have direct adapters don't they ? which completely switch power to AC bypassing battery ? using some two-way switch on the laptop ?
Apple iPad 2 16GB WiFi
30-12-2008, 09:50 PM
Rapacious eBayer
Well, you aren't charging the battery "all the time". Most, if not all, laptops are designed to cut off the power supply to the battery after reaching an upper threshold. My 3-year old Thinkpad used to get me 4.5 hours of battery life back in the day and now gets 4 hours, presumably to cell aging. It's usually on power 24*7.
31-12-2008, 02:13 AM
Wire muncher!
The full charge and discharge cycles funda was applicable to previous generation batteries but not anymore to the newer Li-polymer ones. Its best if you don't let the charge fall below 40%. Plug it in. If AC is available, then use that. But make sure you complete at least one cycle (100 to 0% discharge and then 0 to 100% charge) at least once every 20 days or so to keep the battery in shape.
31-12-2008, 12:03 PM
I know that.. Read the MacBook manuals already!
Thats exactly what happens. Switching.
I must say, Thinkpads are a marvel!
As you have said the directions are for Lithium Batteries, I'll add-up for Nickel ones.
Nickel Batteries need full charge-discharge cycles; otherwise they have something which is called "Memory Effect".
A good reference.
AOC Fovi F22
Reason: Automerged Doublepost
02-01-2009, 07:36 PM
so wat to do 4 making our laptop batteries "last long,really long"
02-01-2009, 07:49 PM
Section Moderator
02-01-2009, 07:59 PM
Originally Posted by gopi_vbboy
thanks 4 the link.:-P
03-01-2009, 12:57 PM
Always confused
well well well I say one thing :
"Laptops while running on AC Power donot have any effect on the battery. It is the case with the older Cadmium batteries and is no longer a problem with Lithium-ion batteries."
@hrnan
I too am using 1525 Inspiron and I get 3 hours of battery on my 6-cell battery.I use the latest powersettings from Dell website (update your power settings from dell's website for 1525 ).This makes for a decent battery life. Happy mobile computing!
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
12-01-2009, 05:34 PM
as far as i know lithium batteries have cycles which is decreased everytime you depend on ur batteries....say if ur lappy is full charge and u drain it completely it will count as one cycle.....if u charge 50% n use dis 50 it will b counted as 1 cycle too....so charge it fully as possible n use batteries only when needed
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
13-01-2009, 04:14 AM
#19 (permalink)
Wire muncher!
No, that would be counted as a half cycle and the cycle count would be incremented after another 50% completes.
Search this Thread |
