Old 29-12-2008, 04:34 PM   #1 (permalink)
Default help with dmc3
i just got dmc3 , but when started it , it didnt work
there were no errors displayed
just the game started and closed down
plz help
my system info is here
System Information
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: Compaq Presario 061
System Model: PY075AA-ACJ SR1520IL FD440
BIOS: BIOS Date: 04/29/05 17:55:16 Ver: 08.00.10
Processor: Intel(R) Pentium(R) 4 CPU 2.93GHz
Memory: 504MB RAM
Page File: 342MB used, 885MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
Display Devices
Card name: Intel(R) 82915G/GV/910GL Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel(R) 82915G/GV/910GL Express Chipset
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2582&SUBSYS_2A08103C&REV_04
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ialmrnt5.dll
Driver Version: 6.14.0010.4299 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 4/5/2005 14:38:44, 38014 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ialmnt5.sys
Mini VDD Date: 4/5/2005 14:46:28, 830684 bytes
Device Identifier: {D7B78E66-66C2-11CF-4763-020AA5C2CB35}
Vendor ID: 0x8086
Device ID: 0x2582
SubSys ID: 0x2A08103C
Revision ID: 0x0004
Revision ID: 0x0004
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
nawnwa is offline
Old 29-12-2008, 04:44 PM   #2 (permalink)
Fighter's Avatar
Default Re: help with dmc3
The problem is with your display device which is Intel(R) 82915G/GV/910GL Express Chipset Family, though you have 128 MB of VRAM but its shared and your native display device cannot render the graphics required to play the game.
You need to upgrade to atleast an independent graphics solution which would be a 9500GT from Nvidia (budget solution)
Core 2 Duo T9600(2.8GHz, 6MB L2 Cache), Vista Ultimate, 15.4" (1440x900) LED Display, 8 GB (800MHz) Dual Channel DDR3 Memory, 7200 RPM Hard Drive 250GB, DVD+/-RW, NVIDIA Quadro NVS 160M1 256MB DDR2
Fighter is offline
Old 29-12-2008, 05:02 PM   #3 (permalink)
well cud u say how much wud it cost
and i forgot to say that its a ripped one
and its total size is 1.61 gb
is it really so or the game is bigger than this
nawnwa is offline
Old 29-12-2008, 05:19 PM   #4 (permalink)
sagar_coolx's Avatar
the one i have is of 3.7gb on dvd...
but rips can vary in size..just because its smaller does not mean it should be non working.
ps: piracy is a bad bad thing...next time im gonna tell ur daddy..
sagar_coolx is offline
Old 07-01-2009, 02:27 AM   #5 (permalink)
ztbryan's Avatar
if you are on a tight budget then a 8600GT graphics card will be more than enough
ztbryan is offline
DMC3 help dOm1naTOr Gamerz 15 26-03-2007 09:16 AM
