Start Registry Editor (Regedit.exe) by clicking Start menu, and then click the Run icon.
In the small box that Opens, type: regedit then click the OK button.
The Registry Editor will now have opened…
Locate the following key in the registry:
HKLM\System\CurrentControlSet\Services\NetBT\Param eters
In the right-hand side of the window find an option called TransportBindName.
Double click that value, and then delete the default value, thus giving it a blank value.
The you must now navigate to the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\OLE
You will see there is a String Value called: EnableDCOM
Set the value to: N (it should currently be Y)
Close the Registry Editor.
Shutdown and Restart your computer
The above procedure closes the port 135 and 445 u can also use windows worms door cleaner to close the port 135 and 445
As there is a utlity that can block the worm doors (windows worms door cleaner).
I can't confirm it works independently without requiring the above procedure as i used it in combination with the above process. Try to use windows worms door cleaner independently and post ur result whether it works for u or not.Use the utility to close
port
135 DCOM RPC
RPC Locator 445 port
As this is difficult to get as most of the people on the internet taking about a small service pack that will help in getting rid of the problem (service pack release in the date of 2004-2005) but my cousin pc is with xp sp3 or all the previous update are there in it but still i try to download the small service pack and try to apply it gives error (u all ready have the updated version some think like this). This problem can also occurs with msblaster worm but as far as i know xp sp3 has all included this patch in it. As even the microsoft site is providing only the old service pack that does not works if u all ready using sp3 patch. It also takes me more than a week to get to the proper working solution
Windows Worms Doors Cleaner
http://download.softpedia.com/dl/31711c0aff2af0c7d627e8819d28dc9f/495ef702/100107294/software/security/firewall/wwdc.exe
Originally Posted by ssnkalol
I Have done this but then after my network is not working.
i get this message while i am using tata easy to surf or dataone new blue modem i which we have to dial for login.
Try to enable net bios port by using the utility
http://download.softpedia.com/dl/a5823a9e140ae47f49ff574c1f1f0f11/495ef880/100107294/software/security/firewall/wwdc.exe
If by opening netbios port it works it good other wise try to open other port also line wise line
