Old 30-05-2005, 02:24 AM   #1 (permalink)
Default System restarts
Hi guys
Sometimes my computer restarts and when windows is loaded it displays a message that "The system has recovered from a serious error" This happens quite rarely (once i a month or so). What could be the cause of the problem.
mako_123 is offline
Old 30-05-2005, 02:54 AM   #2 (permalink)
It could be anything. Right from your Hardware to Software or even Windows XP.
Does it give you any Blue Screen of Death. any error messages? and did you add any new H/W or Software to system.
Post with much more info.
RajŪ Anyone else is not me...!!!
rajas is offline
Old 30-05-2005, 05:09 AM   #3 (permalink)
Me facing this prob too many times......
even i was nt doin any thing tht time.........
N biggest prob is tht it never happens in front of me....
mean (as it happens rarely).....i was out of my room after locking my comp..N whn i came back..it got restarted ......whn i logged in it showed "your system has recoverd from a serious error"....
wht cause behind it might be....as at tht time no program is running....
Very less are thr in world who can understand any new thing in first time.........
ashu283 is offline
Old 30-05-2005, 06:51 AM   #4 (permalink)
I assume the PC's are connected to an UPS. Did you try checking the CPU fan is it working or not?
anupamsinha is offline
Old 30-05-2005, 08:36 AM   #5 (permalink)
expertno.1's Avatar
now for ur solution visit here
http://support.gateway.com/s/issues/667604320.shtml
Note- "I AM NOT RESPONSIBLE FOR ANY DAMAGE CAUSED DUE TO MY ADVICE . THINK BEFORE U FOLLOW ME"
expertno.1 is offline
Old 30-05-2005, 09:52 AM   #6 (permalink)
anomit's Avatar
Well, this is most probably a Graphics driver problem. Update ur Graphics driver and see if that occurs again.
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 30-05-2005, 09:55 AM   #7 (permalink)
anomit's Avatar
Also use memtest to check for faulty RAM modules.
www.memtest86.com/
anomit is offline
Old 30-05-2005, 02:01 PM   #8 (permalink)
I dont receive any blue screen. i also changed my RAM but still the problem occurs. My graphics cad drivers are also upto date.
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 30-05-2005, 11:53 PM   #9 (permalink)
maybe ur system heats up too much.use the free tool "speed fan" to check if the temperatures exceed 75 degrees.
if yes then u hav to buy a new heatsink.
hsksattish is offline
