Old 29-05-2005, 09:33 PM   #1 (permalink)
Default help me on dos
piease suggest a site from where i can see a tutorial on ms-dos.
free of cost of course!
Akhil Jain is offline
Old 29-05-2005, 09:44 PM   #2 (permalink)
Version 2.0
Deep's Avatar
check these links out
http://www.tnd.com/camosun/elex130/dostutor1.html
http://www.c3scripts.com/tutorials/msdos/
or may be this will give you many options
http://www.google.com/search?q=learn...utf-8&oe=utf-8
Regards
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 29-05-2005, 09:56 PM   #3 (permalink)
ok !fine i am trying .
thanx in advance
Old 29-05-2005, 10:00 PM   #4 (permalink)
ooo!!! that will not work.
I WANT MORE DEEEEEEEEEP KNOWLEDGE
Old 29-05-2005, 10:06 PM   #5 (permalink)
Version 2.0
Deep's Avatar
You ask me what specific thing you want so may be i can find it out for u
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 29-05-2005, 10:18 PM   #6 (permalink)
Version 2.0
Deep's Avatar
some more good ones
http://www.animatedsoftware.com/faqs/learndos.htm
and searching in microsoft site itslef will solve many DOS questions and give plenty of knowledge
http://www.google.com/search?hl=en&l...OS&btnG=Search
I had done same while learning about Active Directory
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 29-05-2005, 10:21 PM   #7 (permalink)
THANX FOR SHOWING INTEREST IN SOLVING MY PROBLEM.
WAT I WANT TO KNOW ABOUT IS
NETWORKING IN DOS
MSDOS.SYS FILE
BATCH
DEEP KNOWLEDGE OF HIDDEN TWEAKS IN DOS
& OTHER LOT OF STUFF
LIKE SECUREING FOLDERS , HIDDING THINGS
ALL THESE IN DOS
Old 29-05-2005, 10:46 PM   #8 (permalink)
Version 2.0
Deep's Avatar
seriously google is a wonderful place...
i fetched some stuff for you..
Networking in DOS - http://www.mwpms.uklinux.net/page6.htm
http://www.duxcw.com/dcforum/DCForumID2/91.html
DOS Based Microsoft network server - http://www.wown.com/j_helmig/dosservr.htm
Contents of MSDOS.sys - http://support.microsoft.com/kb/118579/EN-US/
How to create an Msdos.sys file larger than 1024 bytes - http://support.microsoft.com/?id=129998
some stuff on batch files
DOS BATCH FILE TUTORIAL - http://www.chebucto.ns.ca/~ak621/DOS/BatBasic.html
Dos Batch File Examples - http://www.chebucto.ns.ca/~ak621/DOS/Bat-Samp.html
DOS Batch Programming - http://www.ericphelps.com/batch/
Hope this helps you
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
