Old 29-05-2005, 07:16 PM   #1 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default WHICH 800VA UPS IS BETTER?
Guys just wanted 2 buy a 800va ups. Confused as 2 which brand is better and has better service. Here in Kolkata most of them suggest microtek as it has double back-up. Service is also a concern? Plz help.......
john_the_ultimate is offline
Old 29-05-2005, 07:32 PM   #2 (permalink)
The Hardware Labs
mohit's Avatar
apc is the best brand for UPS' but its damn expensive ... others are tvs, numeric,wipro ... keep away from microtek. apc and numeric have very good service response.
mohit is offline
Old 29-05-2005, 08:33 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
U can go for NUMERIC UPS, i am using it for almost 3 years now without any problems.
But before buying plz do check with ur city that does it provide enough "sales after service" for NUMERIC brand of UPS or not.
If not then u can go in for MICROTEK, as they r also good enough for backup solutions...
cheers n peace...
ashu888ashu888 is offline
Old 29-05-2005, 11:15 PM   #4 (permalink)
lavan_joy's Avatar
APC is the best choice. Service is so good. But a little bit expensive.
Many times they send a replacement with a new one instead of repairing the old one.
LAZINESS IS THE ENEMEY OF SUCCESS
lavan_joy is offline
Old 29-05-2005, 11:54 PM   #5 (permalink)
go for APC in budget permits otherwise Microtek and otherwise affordable brands
Windows XP Pro Service Pack 2 build=2600
Mobo- MSI PM8M-V
GenuineIntel Intel(R) Pentium(R) 4 CPU 2.40GHzRAM : Installed : 512 * 2 MB DDR RAM (TRANSCEND)
XFX FX5200 128 MB
medigit is offline
Old 30-05-2005, 12:23 AM   #6 (permalink)
APC service is VERY VERY area specific. Call APC Bangalore and ask them about service and backup in Calkata (or is it Kolcutta). Generally you can expect a honest response. If there is NO APC centre in your city, then getting a backup unit (swap warranty) is not possible. APC tend to concentrate on certain cities/towns and do a good job of providing decent service. So if you're not on their map, better take your business elsewhere.
APC India product selector - http://www.apc.com/tools/ups_selector/index.cfm
Keith
Keith Sebastian is offline
Old 30-05-2005, 10:07 AM   #7 (permalink)
Also, whenever some1 mentions APC;they usually end up saying this in the same sentence: "After-sales is gr8,they replace UPS by courier" Which kinda leaves a bitter after-taste!! I have been using Non-APC UPS for 5yrs now, & never had even a single problem!! Didnt even had to change the battery on it!
delhibhai1000 is offline
Old 30-05-2005, 12:43 PM   #8 (permalink)
rohanbee's Avatar
APC is quite good and very expensive. I know my company owns quite a few variants. Service is ok, it also depends what area you are in. Maybe you being in a metro might have a dedicated apc service center.
Also, your usage is also a main criteria, if its just home i dont suggest going in for such a high end brand the other normal ones will be just as good.
Quote by Garfield'
rohanbee is offline
Old 30-05-2005, 04:58 PM   #9 (permalink)
Infact I'd advise you to got for an APC. If they can assure you of service in your area, that is.
800VA is an overkill. You can get a 500VA APC for INR 2800 and 650VA for INR 3600.
Just use the UPS selector link in my previous post.
Keith
Old 30-05-2005, 05:03 PM   #10 (permalink)
Here's APC Calcuttu contact details -
For sales info call Tarun - 98300 25473
Or ring office (033)2463 0063, 2463 0064 between 9:15am and 6:00pm
at
768,Lake View Road
Kolkata, West Bengal 700 029
India
Next to Raymonds showroom on Southern Avenue or diagonally opposite to Ashoka Building
Keith
Old 30-05-2005, 07:55 PM   #11 (permalink)
No pain....No gain
Thank u guyz. This was my first post. Got an rough idea as 2 what 2 buy. APC has a price which is out of my budget so got an microtek 800VA @ INR 2366 tax included. The 2 battery one. Thanks again....
Old 31-05-2005, 10:54 AM   #12 (permalink)
Don't go for Microtek it sucks.....
Go for Numeric it is one of the best..
shivaranjan.b is offline
