Old 25-12-2008, 04:03 PM   #1 (permalink)
Default DVD Burning Error
Hi guys,
I've a Sony DVD RW DRU-190A and recently i got an error while i was writing a 4 GB DVD using Power ISO software.
The error code is Burning failed(-109, 987a9b5c).
And i can't write any dvd.....
Vasiq is offline
Old 25-12-2008, 04:12 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: DVD Burning Error
Possibilities:
* The DVD media you are using is causing problem with your DVD writer, try using another media.
* Clean the DVD writer using Lens Cleaner
* The lens may get replaced, time to repair or replace if under warranty. If not go for LG or Samsung
Also try burning the DVDs with other softwares like Nero and try to reduce the file size.
- MrinTech :)
mrintech is offline
Old 25-12-2008, 05:34 PM   #3 (permalink)
Try burning some other DVD, if that too fails, then surely it is a problem with your lens.
ico is offline
Old 25-12-2008, 08:26 PM   #4 (permalink)
Originally Posted by mrintech View Post
Possibilities:
I'm using National and i've Sony DVD RW190A writer and i've tried using other softwares like with Nero after 100% it froze and using Power ISO i got an burning failed error
i've wasted 3 dvd's but the first one worked perfectly but after that when it started freezing on 100% using nero software any solution.....
Vasiq is offline
Old 27-12-2008, 01:32 AM   #5 (permalink)
jal_desai's Avatar
I had several problems with National... I know it is widely available and cheap so obvious for anyone to go for it.but try using moser baer or frontech atleast that has 16X written on it.. lesser than 16x caused problems for me. Use InfraRecorder for burning it.
TechExplorer.in
jal_desai is offline
Old 27-12-2008, 08:15 PM   #6 (permalink)
Thank you for the suggestion but now it's working fine actually there was some problem in the burning software itself.
Vasiq is offline
External Casing+DvD burner giviing burning fail error ? multi Software Q&A 1 23-07-2007 12:37 PM
"Positioning Error" while burning of CDs with Nero modern_crusader Software Q&A 1 21-09-2006 09:20 AM
Nero 7 burning error.....please HELP!!! pirates1323 Software Q&A 2 02-04-2006 06:30 PM
Nero Burning ROM error Gaurav Software Q&A 8 22-08-2005 04:54 PM
burning error pls help quick.... sanjeev choudhary QnA (read only) 2 16-04-2005 05:57 PM
