Old 22-12-2008, 11:33 PM   #1 (permalink)
Default home theatre under 18k
hi friends i want to buy home theatre under 18 k,
can anyone tell me which is the best .
should go for sony or samsung ?
can i play 5.1 movies in avi format using pendrive in it or my bluyray rip movies(.mkv) using pendrive .
i checked samsung HT-TZ312T i found its bluetooth funtion very good , is it good to buy ?
thanks
frogonfloor is offline
Old 23-12-2008, 07:53 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: home theatre under 18k
I would say go for Philips or Sony for Home Theatre setup. Samsung is nowhere near to these two when it comes to audio and video performance.
Check this one with wireless rear speakers and comes with speaker stands too: http://www.sony.co.in/product/dav-dz570
this one too: http://www.sony.co.in/product/dav-dz270
From Phlips: http://www.consumer.philips.com/cons...tem+HTS3366-98
desiibond is offline
Old 23-12-2008, 10:02 AM   #3 (permalink)
parthbarot's Avatar
go for philips or samsung for HT system.You will get it in your budget man...
And yah..before taking it, you must check if it supports USB pen drive or not.Mostly you will get a divx/xvid player..which will play your AVIs and if its having 5.1 AC3 audio..then u will get it in ur HT
i got Passion DVD player from BigBazzar... in just 1300 and 6 months warrenty..which plays USB mp4 also!
so..best of luck
regards.
www.techlads.com
Paarth.
parthbarot is offline
Old 23-12-2008, 10:21 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ i do object that bigbazaar dvd player. seriously, if you want quality, stay away from that cheap crap ****!!! No offense meant.
and you do have to try out Sony HT's audio quality
Old 23-12-2008, 01:07 PM   #5 (permalink)
AFK
thewisecrab's Avatar
Go for a philips HT. I heard that its about 12K and will suit all your requirements.
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 23-12-2008, 05:10 PM   #6 (permalink)
PowerDaemon
Musicmaker23's Avatar
Go in for a Samsung without fail. Sony comes second for me & philips is nowhere on my list.
Samsung HTs are better looking, come with more tech & much much nicer speakers than philips though i guess sony can give it quite some competition.
bluetooth enabled ones will cost u a bomb n are difficult to setup according to my sources.
if you spare a lil' more cash, buy what i have - Samsung HTX250 - got a usb port which'll play your .avi files easily... & did i mention it looks good enuf to make u drool? you might be able to get it for around 22k now
http://www.samsung.com/in/consumer/d...d=HT-X250T/XTL
otherwise,
http://www.samsung.com/in/consumer/d...=HT-TZ315T/XTL with tower speakers 1000W sound, usb host rs.18k
or,
http://www.samsung.com/in/consumer/d...d=HT-Z210T/XTL usb host, 800 w sound rs.12k
HP dv9222tx+
MeanMachine: [Intel Core2Quad Q9300 2.5Ghz] [Asus P5-KVM] [4GB RAM 800Mhz] [nVidia XFX GeForce 8600 512 MB] [500GB WD SATA] [Sony 20x ODD] [Neotech 600W SMPS][Vista Ultimate+Office07]
Musicmaker23 is offline
Old 23-12-2008, 08:52 PM   #7 (permalink)
thanks for all your reply i am thinking to buy HT-TZ312T it have tover wireless speaker .
above all it have bluetooth function it was awesome to use it play songs from mobile .
but i want to know "can i play my bluyray rip movies(.mkv) using pendrive"
Old 23-12-2008, 10:22 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^no. it won't recognize mkv format. I tried to do that on couple of players but didn't work.
Old 23-12-2008, 10:25 PM   #9 (permalink)
AFK
Nope. Most HT systems dont support .mkv format. DivX, Xvid will work in most though.
Old 23-12-2008, 11:38 PM   #10 (permalink)
thanks
Home theatre set up shariq_pj Hardware Q&A 30 23-02-2007 02:01 PM
5.1 home theatre mandar5 QnA (read only) 2 17-01-2007 09:35 PM
Need Intervideo Home Theatre maddydilip QnA (read only) 1 08-12-2004 02:33 AM
Home Theatre Shikhar QnA (read only) 3 05-12-2004 12:28 AM
