Old 29-05-2005, 01:02 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default ARE RAM OPTIMIZERS OF ANY REALLY HELP ! ?
They are not, says studies ! it says they have no effect, and at worst, they seriously degrade performance. Although gaining more available memory might seem beneficial, it isn't. As RAM Optimizers force the available-memory counter up, they force other processes' data and code out of memory !!! you may have noticed, that after using a ram optimizer, it does take time for aplication to re- or cold- start ! for just-closed applications, they may however help in unloading their dll's.
pls visit http://www.windowsitpro.com/Article/...095/41095.html &
http://mywebpages.comcast.net/SupportCD/XPMyths.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 29-05-2005, 01:52 PM   #2 (permalink)
Gaurav's Avatar
No they don't help much you can't expect miracles from such softwares
Gaurav is offline
Old 29-05-2005, 02:28 PM   #3 (permalink)
The Hardware Labs
mohit's Avatar
they are useless and harmful according to me.. they sometimes freeze ur machine and cause errors in running processes ... better to avoid them and go for physical ram upgrade. and if ur system has less amount of ram then just disable all the frills and effects... that will surely be helpful.
mohit is offline
Old 29-05-2005, 07:19 PM   #4 (permalink)
Gracias Senor
dreams's Avatar
ya they r useless.. when v free up RAM itselfthe sys hangs for soetimes and after tht the sys goes unstable.. unless and until u restart it will never cum 2 stable state.. this is of my exp..
..Shar n nJoy..
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 29-05-2005, 07:44 PM   #5 (permalink)
Tux
Posts: n/a
Sys mech's RAM defragmenter is very useful. try it
Old 29-05-2005, 11:03 PM   #6 (permalink)
sidewinder's Avatar
They r just shits! They r of no use....
Bombina rocks
sidewinder is offline
Old 30-05-2005, 03:46 AM   #7 (permalink)
RAM Boosters/ Optimizers they suck alot of RAM.
Raj® Anyone else is not me...!!!
rajas is offline
Old 30-05-2005, 03:52 PM   #8 (permalink)
Already discussed and that time too these optimizers where found to be crap.One interesting post was that if they were so helpful why didnt microsoft include ram optimizers in the kernel
vasanth_12345 is offline
Old 30-05-2005, 05:16 PM   #9 (permalink)
rohanbee's Avatar
Ram optimisers are a " Get rich quick scheme of some software programmers" They optimise memory and minimise all other operations.
Better stay away
Optimise Ram by buying good hardware ram!
Quote by Garfield'
rohanbee is offline
Old 31-05-2005, 12:33 AM   #10 (permalink)
sms_solver's Avatar
Better to have a lot of RAM (1GB+) rather than installing these softwares.
Beside WinXP manages memory effectively!
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 01-06-2005, 03:43 PM   #11 (permalink)
club_pranay's Avatar
they only eats up more resources
i never recommend them
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 01-06-2005, 07:40 PM   #12 (permalink)
used to be of my help when i used to have 128MB of SDRAM.... not of use as of now since upgraded my machine to 1gig of RAM ...
grinning_devil is offline
Old 02-06-2005, 01:07 AM   #13 (permalink)
deathvirus_me's Avatar
mem. optimizations by winxp are good enough ... ever noticed the free ram before/after playing games like d3 , MoH : PA ??? the os shuts down unneccesary services itself .... good enough for me ... i trust a very few third party softwares ....
deathvirus_me is offline
Old 02-06-2005, 03:16 AM   #14 (permalink)
Krazy_About_Technology's Avatar
Agree with deathvirus_me. Windows XP's memory management is good enough. RAM optimizers increase the amount of free phyisical memory but they cause heavy paging operations, as programs are moved to page file to free memory. N if you got a slow or problemetic hdd, you are in for a real bad time.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 02-06-2005, 04:58 PM   #15 (permalink)
montsa007's Avatar
exactly they worsten ur pc
montsa007 is offline
Old 02-06-2005, 05:58 PM   #16 (permalink)
If you have more than 256 megs of RAM you'll find that these optimisers are useless. They where designed for older generation machines (with low and slow memory susbsytems) running older OS's (< win 98) that could not manage system memory very well.
Keith
Keith Sebastian is offline
Old 20-09-2006, 09:28 AM   #17 (permalink)
EagerBeaver's Avatar
Default Re: ARE RAM OPTIMIZERS OF ANY REALLY HELP ! ?
Even I thinks it is useless. WXP has good memory management system..........
But what is the difference between memry optimizers and memory defraggers ? Like system mecanic has both ???????????????????????
FREEDOM ROCKZ...ATTITUDE RULZ
EagerBeaver is offline
Old 23-09-2006, 08:51 PM   #18 (permalink)
Tux Fan
shaunak's Avatar
USELESS
one word.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 23-09-2006, 09:19 PM   #19 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
F***IN ****
another word
rakeshishere is offline
Old 23-09-2006, 09:28 PM   #20 (permalink)
gooby pls
Third Eye's Avatar
Ram optimizer softwares are useless and built only for making money.
Third Eye is offline
Old 23-09-2006, 11:14 PM   #21 (permalink)
Stalker's Avatar
A gud Memory Manager Program
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 25-09-2006, 12:05 AM   #22 (permalink)
The Sexy Beast
they hang up all the processes until the value set is reached.i get pissed off when something like this happens when i'm playing f1 especially when i'm on myflying lap.
ratedrsuperstar is offline
Old 16-10-2006, 02:49 PM   #23 (permalink)
powerd ↻ pramod
GeeNeeYes's Avatar
Thumbs up of course they are :P
yus the software available in market / on internet are usually useless
but not all memory optimizers are bad
SOME ACTUALLY DO HELP N OPTIMIZE MEM
i have one... try it... you will immediately love it..
its really tiny (only 15KB).. shows the free mb of RAM
green LED display in systemtray... turns yellow or Red depending on the percentage of sytem RAM that is free
takes little or no memory or CPU cycles
its user-friendly.. its not automatic.. you choose when you want to optimize
it frees memory by 25-50% depending on the processes
you can see the effects usually immediately after executing it n choosing AutoFree option
digit member #17000
GeeNeeYes is offline
Old 16-10-2006, 03:59 PM   #24 (permalink)
Come get Some
DukeNukem's Avatar
I totally disagree with you Bros.
iam runnin Windows XPSP2, using cachemanXP and it serves its purpose takes only .8 to 1.4MB of my ram
and manage to save lot more than.
Plus there are other uses of its also
Like killing a process which sometimes even task manager cant do.
DukeNukem is offline
Old 16-10-2006, 04:01 PM   #25 (permalink)
samrulez's Avatar
Ram optimizers are good if u have less than 256MB memory for XP and 512MB for Vista...if u have above 1GB then no need of using optimizers!
Sam :D Rulez :lol:
samrulez is offline
Old 16-10-2006, 04:27 PM   #26 (permalink)
Come get Some
DukeNukem's Avatar
Cool Re: ARE RAM OPTIMIZERS OF ANY REALLY HELP ! ?
Friend My Other friend's PC config goes like this
P4 2.8Ghz (800Mhz Fsb 1Mb Cache) 1GB DDR (400) i865 running Windows XPSP2
without using Cacheman available ram jus ater booting and after 15 minutes is like this 300MB and 395 MB Resp (checked using smalltool).
With Cacheman its 875MB and 899 MB Resp.
See the diff
Old 16-10-2006, 10:38 PM   #27 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
these softwares are useless...they screw up the system..
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 18-10-2006, 04:24 PM   #28 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
I dunno about other RAM applications, but FreeRam XP serves it purpose well... It doesn't suck out RAM space to free it. Ensures cr@p to stay out of the RAM whenever a stress is on it and enhances ur computer experience. Goin with SamRules, these sorta utilities are for those who have low RAM, around and under 256Mb, they feel the difference. Anything higher and RAM issues seldom trouble you.
FreeRAM XP just gets rid of applications which are not used for the moment whenever necessary or when forced. This way, more RAM space is available for other utilities. Exp useful when running intense applications like games.
koolbluez is offline
Old 03-11-2006, 12:28 PM   #29 (permalink)
SymbianGeek
Yup they do help when u have low configs.
We had once installed WebLogic server on one machine and it used to take quite some memory.so to keep it fast and running this tool helped us a lot.
--eminemence.
eminemence is offline
Old 03-11-2006, 12:57 PM   #30 (permalink)
I have 256mb RAM still find hard to run xp smoothly, how can you manage?
Stick is offline
