Old 20-12-2008, 04:15 PM   #1 (permalink)
sushan's Avatar
Smile i couldnot install Kasperksy 2009
Dear fresns,
it is very urgent!
I have install kaspersky 6.0 and uninstall it but it still shows "Kaspersky 6.0 antivirus is off" and i tried to delete the registry but couldnot do so.
Secondly. i tried to install kaspersky 2009 but it says " there is still another antivirus(it shows avg 8) ,please remove and proecedd with the installation" but i have deleted avg 8 manually going to the registry and still shows the same,i have searched avg but couldnot find.
why it so?
Plese help me!
best
Sushan
HrD 2 tackle TeCHH ProbLemmS
Free Latest gadjets at http://www.xpango.com?ref=92545037
sushan is offline
Old 20-12-2008, 04:28 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: i couldnot install Kasperksy 2009
It sure looks like you missed something in the registry...use revo uninstaller to uninstall all AVs...try disabling startup items too as something maybe running during startup preventing KIS to be installed
My site: collegeclassroom.org
amitash is offline
Old 20-12-2008, 04:43 PM   #3 (permalink)
my name defines me
cyber's Avatar
use tune up utilities and use the tune up shredder option to delete the software fully
cyber is offline
Old 20-12-2008, 05:58 PM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
http://www.revouninstaller.com
- MrinTech :)
mrintech is offline
Old 21-12-2008, 01:02 PM   #5 (permalink)
sushan's Avatar
i have run registry mechanic 2008 many times and too i have revo uninstaller but it doesnot help me,still it does the same problem and shows the same.
best
Sushan
sushan is offline
Old 21-12-2008, 05:29 PM   #6 (permalink)
Click Start button
Go to Run and type "regedit" (type without quotes)
a) use Ctrl + F and type AVG8
or
a) directly go to HKEY_LOCAL_MACHINE\SOFTWARE key in the registry and you will find AVG folder, remove that and try to install Kaspersky. It will work.
In future you should install an uninstaller software. This will help you remove all the files left back from unstalled software
http://www.darkdump.com
jrkraj is offline
Old 23-12-2008, 04:27 PM   #7 (permalink)
JojoTheDragon's Avatar
You posted this problem before. Are you a jerk or what?
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline
Old 31-12-2008, 10:34 AM   #8 (permalink)
sushan's Avatar
Cool Re: i couldnot install Kasperksy 2009
I thought there might be virus which restrict me to eject pen drive continously from PC,so I tried to install the KAspersky 2009 but ir coulld not install;FYI, I have kaspersky v 6.0 which is turned off(shows by system tray when the PC is logged on)
The following msg appeares whenever i tries to install the antivirus:
Error 1923: Services Kaspersky Anti-virus(AVP) cooulnot be installed.Verify that you have sufficient privileges to install system services
Abort Retry Ignore
sushan is offline
Old 31-12-2008, 10:53 AM   #9 (permalink)
Answers everything
mmharshaa's Avatar
Just download the application Ccleaner from this site and install it on your machine..
It will help in removing all the unused registry entries along with temporary files..You can uninstall the programs too...Then try installing your new KAV 2009 then... It will work fine..
www.ccleaner.com/download
The ultimate solution for all your pc problems: My answer
mmharshaa is offline
Old 31-12-2008, 12:47 PM   #10 (permalink)
Wise Old Mouse
mrintech's Avatar
Abort Retry Ignore
Browse through: http://www.google.com/search?hl=en&s...)+&btnG=Search
- MrinTech :)
mrintech is offline
Old 31-12-2008, 09:06 PM   #11 (permalink)
afonofa's Avatar
Lightbulb Re: i couldnot install Kasperksy 2009
If you uninstalled Kaspersky v6.0 then it should not be in the system tray.
Use the tools linked on the Removing other anti-viruses thread at the kaspersky forum and the removal tool for Kaspersky 6.0 to remove any traces of avg and kaspersky. Kaspersky also provides their own avg removal tool.
afonofa is offline
Autodesk has announced the new 3ds Max 2009 and followed with new 3ds Max Design 2009 elenec Random News 4 30-12-2008 10:55 PM
I couldnot install antivirus,why? sushan Software Q&A 13 21-11-2008 09:17 PM
WiCOM 2009 Call for Papers: Sept. 24-26, 2009, Beijing, China wendy88520 Hardware Q&A 2 14-11-2008 02:56 PM
Symantec introduces 2009 range of products including NORTON ANTIVIRUS 2009 apoorva84 Technology News 34 19-09-2008 11:01 PM
Autodesk has announced the new 3ds Max 2009 and followed with new 3ds Max Design 2009 elenec Random News 4 21-02-2008 09:09 PM
