Old 20-12-2008, 12:08 AM   #1 (permalink)
Default connect 2 comps and share net
I have a desktop and a laptop, the desktop is connected to the net.
Desktop has Win XP SP3 whereas the laptop has Win Vista Home Premium.
I want to connect both the comps through a lan cable for the purpose of file transfer and lan gaming besides I want the net connection on the desktop to be made available on the laptop as well.
Can u please help me on how to achieve this. Thnx in advance.
It is better to light a candle than to curse the darkness.
Shikhar is offline
Old 20-12-2008, 12:41 AM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: connect 2 comps and share net
I have no hands-on experience with this, but just yesterday I too though about this. I found that it can be done via cross-over ethernet cable. Plz read the below link:
http://compnetworking.about.com/od/h...ecttwocomp.htm
Also, if you can invest, you may go for Wireless LAN network(WLAN). Since you have a laptop, it may be more valuable as well. Please see this thread ==>Installing Wi-fi at my home
I just enquired today at Thane, the price for wireless LAN router starts at 1850. Also you will need a wireless LAN card. I will checkout the prices at the Lamington road soon
गीक होना माँगता
victor_rambo is offline
Old 21-12-2008, 09:05 AM   #3 (permalink)
An Esoteric Geek
sridatta's Avatar
Hi Srikhar
Your problem is very simple. Just buy a router. Since you have a laptop, I would suggest to go with Wifi router which would be available everywhere.
Your ADSL broadband modem would be connected to router which will have atleast 4 Ethernet ports. You can use one Ethernet port to connect to Desktop. From laptop, you can use the either way (Ethernet or wifi if you have wifi). And, to play games, I would suggest you to connect both PC and laptop to ethernet for better bandwidth.
So, in short, buy a router. It would solve all your requirements irrespective of what OS you have.
sridatta is offline
How to Connect Two Computers Via BSNL Broadband n share files simultaneously ?? saboo.dinesh Hardware Q&A 15 25-10-2009 01:01 AM
Coneccting Comps azzu QnA (read only) 13 22-05-2007 12:31 AM
How To Connect Nokia 3230 With PC Via BT To Share Internet? Devrath.N.D Mobiles and Tablets 3 09-09-2006 11:46 AM
tuorial to connect ur mobile with pc through bt and then share the net and good speed the.kaushik Tutorials 2 03-09-2006 05:45 PM
How to connect to computer to share files? divyadbzgt1 QnA (read only) 2 22-08-2005 01:33 PM
