Old 28-05-2005, 09:09 PM   #1 (permalink)
Default ups problem
i have an offline ups but when power goes out my computer keeps on restarting and never goes beyond the booting screen what could be the problem.earlier it used to work fine.
Tommygecko is offline
Old 29-05-2005, 01:26 AM   #2 (permalink)
Version 2.0
Deep's Avatar
what i feel is...battery problem...
i had faced same problem with my APC UPS, i called them up, the guy came next day and fixed it...
try connecting pc withouht UPS to cross check...
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 29-05-2005, 09:44 AM   #3 (permalink)
dinesh_singh
Posts: n/a
yah buddy ur ups needs some kinda repair or replacement
most prob...ur ups batt has done its job.
Old 29-05-2005, 07:13 PM   #4 (permalink)
Gracias Senor
dreams's Avatar
batteries gone.. replace it and do chk ur sys without UPS as told by Deep..
Also chk ur Power Supply cos this may b happ due to constant voltage fluctuations which must hv spoiled ur batt.. unless and until it is rectified u cant use UPS even if u replace it..
..Shar n nJoy..
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 31-05-2005, 12:14 AM   #5 (permalink)
i had similar problem.maybe ur battery is not charging up even if mains is on.u first hav to check the circuitry with a technician an then think abt a new battery.
hsksattish is offline
