Old 28-05-2005, 01:04 PM   #1 (permalink)
The Incredible's Avatar
Default "PCI-e" = "PCI + AGP + mor speed"
Hi
i wanna know that do PCI-e support PCI n AGP devices?
also is it mor powerful & fast than da abuv two?
Do u know abt any PCI-e based mid range mobo for AMD?
Help needed.
The Incredible is offline
Old 28-05-2005, 02:11 PM   #2 (permalink)
rohanbee's Avatar
As far as i know the Pci-express does not support any AGP device because agp is a different standard altogether. What i have read is that (this pertains to graphics cards specifically) while pci-express based cards can be installed with a bridge attached to them on an agp based mobo.
Pci-e x 16 is supposed to be twice the speed that of an agp 8x however no reviewer has been able to prove that pcie in anways is faster than the agp at the moment.
However technology pundits do predict that as technoogy progress we will get to see the true power of this new interface. So its a game of waiting and watching at the moment.
Quote by Garfield'
rohanbee is offline
Old 28-05-2005, 05:02 PM   #3 (permalink)
dinesh_singh
Posts: n/a
very true....at present agp and pcie dont have much diff in performance.
and you cant install pcie over an agp .....normally
and abnormally you can always do anything u wish too....
consider running a amd athlon xp 3200 barton on asus a8n sli mobo.may be it will work.
Old 28-05-2005, 07:49 PM   #4 (permalink)
Well man i asked that will agp work in a PCI-e slot?
n i mnt any PCI-e based mobo which fully compatible with AMD CPU's.
i wanted 2 know da mobo's n CPU's supported by them.
Also, will pci card work in a PCI-e slot?
Is PCI-e also faster than PCI?
Old 29-05-2005, 09:02 PM   #5 (permalink)
see http://www.tomshardware.com/index.html
agp and pci-e cards have different cuts so they definitely 100% CANT work in the same slot .. the site will show u the different snaps .. makin it easier for u to see y they DONT work together ..
AMD Athlon 3500+ 939
Asus A8N-E
HDD: 860GB = 250 x2 + 160 x 2 + 40
Nvidia XFX 7600GT
2GB DDR RAM 400Mhz Transcend
17" LCD Viewsonic
ASUS Sata DVD writer
Logitech MX 518 + Steelpad Qck+
CyCo is offline
Old 29-05-2005, 10:31 PM   #6 (permalink)
Busy Bee
Raaabo's Avatar
I have an MSI RS 480 motherboard... supports AMD 64-bit 939 pin CPUs and 4 DDR 400 MHz memory slots and has 1 PCIe slot. It's about Rs 6,500 to 7,000 and is perhaps the best "cheap" alternative to have the option to add a PCIe graphics card later.
Raaabo
This Forum has rules:
Read them, or else!
Compute Rig: Phenom II X6 1090T | Crosshair IV Formula | 8 GB HyperX DDR2 | XFX HD 6850 | 2 x 300GB Velociraptor (RAID 0) + 1.5 TB Barracuda | Win Pro 64
HT: Denon 1912 | Jamo S608 HCS 3 | Jamo Sub 300 | PS3 | TataSky+ HD | Philips 32PFL5609/98
ICE: Sony Xplod DSX-S100 | Sony Xplod XM-GTX6020 | PowerBass S-12 | 4 x Blaupunkt IC (doors) | 2 x Alpine SPS-609 (rear-mounted)
Guitar Rig: Slammer CT 212 Metallic Red | Yamaha Pacifica PAC012 | Line 6 Pod X3 Live | Beta Aivin MX 30 | Marshall MG 15 CD | Korg ToneWorks AX100G
Raaabo is offline
Old 02-06-2005, 01:19 PM   #7 (permalink)
Raaabo
Can u tell me mor abt ur mobo.
How much was da total cost of ur rig?
Don't u know any mobo having 2 PCI-e slots.
Also, what da speed of ur PCI-e Bus.
Old 03-06-2005, 12:01 AM   #8 (permalink)
all the 3 , i.e. , pci , agp n pci-e have diff slots . so u cant mix n match the diff cards u have , coz they wont simply fit
pci-e 1x is faster than the normal pci slot , leave out the 16x 1z
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline
Old 03-06-2005, 12:39 AM   #9 (permalink)
But i heard that PCI-e slots also support PCI cards. Isn't that true?
Old 03-06-2005, 07:14 AM   #10 (permalink)
q3_abhi's Avatar
I think that isnt true.N AGP cards wont fit in PCI-e slot.Presently though there must be no difference between AGP n PCI-e,the future cards will be based on PCI-e. SO go for PCI-e if u wanna play future games
q3_abhi is offline
Old 04-06-2005, 12:35 AM   #11 (permalink)
where frm ??
told u bout 1x being faster than pci . if u have seen what a 1x slot looks like , its bout 1/3rd to 1/4th the length of the pci slot . also the part of the card which slots in , in pci , therez a bump ( some of the array missing ) at the rear end , where as in pci-e , this ' bump ' is at the front . so no question of pci fitting in2 a pci-e slot
mamba is offline
Old 04-06-2005, 12:55 AM   #12 (permalink)
pci-e 1x is faster than a nprmal pci slot in all respects.
**** happens
pradeep_chauhan is offline
