Old 28-05-2005, 03:09 AM   #1 (permalink)
Default Sound card is notworking can any body help me !
hi
can any body help me, i have a system p4 2.6 Ghz 256 mb ram & ADI sound max audio card installed with linux 9. my problem is sound card is not working , some error is comming while login in.i have attached the picture, can any body help me to solve the problem.
thanks in advance
http://img217.echo.cx/my.php?image=snapshot17bt.png
prasannaraja is offline
Old 29-05-2005, 04:40 PM   #2 (permalink)
The Incredible's Avatar
Default Re: Sound card is notworking can any body help me !
Originally Posted by prasannaraja
hi
thanks in advance
First of all STOP LAUGHING!
next b4 posting also provide what were u doing when u got thy mssg.
It seems that da program cannot initialize with ur drivers.
Whatever is written try it one by one, if it doesn't works try da other step.
Reinstall da program.
Reinstall da drivers.
Chech for any spyware, viruses.
Download a fresh copy of ur drivers. n reinstall them.
Hop this works. if i hav said sumthing wrong plz correct me.
The Incredible is offline
Old 29-05-2005, 07:00 PM   #3 (permalink)
Gracias Senor
dreams's Avatar
the same prob occurred with me also.. its cos Linux doesnt support most of the Intel Products.. i used linux 8 and 9 but the same prob.. try installin Linux 10 and also try reinstalling the drivers and also try to update the drivers.. cos the older versions may not work in specific linux and so a update must b avail.. chk it out..
..Shar n nJoy..
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 01-06-2005, 11:17 AM   #4 (permalink)
Thank u very much Guys !
i got the driver from Intel website now it is working good.
once again i thank DIgit forum for the help .if anybody want the same can be
Download from this link.
http://www.intel.com/design/motherbd..._drive.htm#rh9
thanks
prasanna
