Old 28-05-2005, 12:30 AM   #1 (permalink)
Default guys quickhelp needed (Kolkatans)
can any body pls tell me the setting for the dataone bsnl broadband connection?
pls reply quickly
Happy Computing :lol:
krishnathelord is offline
Old 28-05-2005, 12:39 AM   #2 (permalink)
QA Juggler
saROMan's Avatar
what setting???
for 98/XP ???
plz elaborate ur qs
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 28-05-2005, 01:28 AM   #3 (permalink)
i hv dual boot with 98 as well as xp so pls give be both
Old 28-05-2005, 05:59 AM   #4 (permalink)
d
in XP, Jus use the new connection wizard, with a broadband connection with lan over PPPoE...I think for this you will need to go to network
connections->Create a new connection->connect to the internet->set up my connection manually->connect using a broadband connection....->Then type in the ISP name and then the user name and password. This should do it in XP. About 98, I will have to confess my ignorance =)
The torquemaster rules.
d is offline
Old 28-05-2005, 09:43 PM   #5 (permalink)
For connecting DataOne in Win98 you need to install PPPoE software available on Calcutta Telephones website.
For complete guide on DataOne use this link
naveenpoddar is offline
Old 28-05-2005, 10:00 PM   #6 (permalink)
QA Juggler
saROMan's Avatar
well i think in some other post..i have given the patch files req to conn 98 thru dataone..plz do a search.....
saROMan is offline
Old 29-05-2005, 01:39 AM   #7 (permalink)
tried with xp in vain
heard some thing about always on connection for that just have to switch on the modem and ur through
