Images are binary. Why would you want to encrypt them with ascii code?
If you are looking for ASCII Art, Google "ascii art c++"
Actually im working on project "image encryption/decryption into ASCII".If i can do it in other language then pls suggest me. i can do it in java as well as vb.net other than c++.
Thank you
