Old 27-05-2005, 11:28 PM   #1 (permalink)
nix
Senior Member
nix's Avatar
Default drop shadow error
the icon labels on the desktop alays have a blue background. so i enabled drop shadow for icon labels from control panel. but still, the blue background for the text does not go? help please.
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
nix is offline
Old 29-05-2005, 06:56 PM   #2 (permalink)
The Incredible's Avatar
Default Re: drop shadow error
Next Time when u post plz mention ur OS also.
If u r having Win 98 SE. Then follow da steps below.
Right click on ur desktop.
Click on appearance tab
Go to Item area.
Select "Selected Items" options
Now luk at da right side, a color option will be there.
Select da color desired.
Voila! UR PROBLEM SOLVED.
Bye.
The Incredible is offline
Old 29-05-2005, 07:36 PM   #3 (permalink)
 Macboy
goobimama's Avatar
This problem has been discussed and solved in a topic started by me.
here's the link
Desktop icon problem
I'm like a bird... :)
goobimama is offline
Old 31-05-2005, 10:00 AM   #4 (permalink)
nix
Senior Member
nix's Avatar
Default hi
thnx it now works. the lock desktop items had been checked.
i had almost lost hopes of someone replying to this topic.
nix is offline
Old 31-05-2005, 02:35 PM   #5 (permalink)
Default Re: hi
Nix sum 1 told me never 2 lost hop. There's always a solution for a question. God is upon every 1 . He helps everyone but u too hav 2 do sum work. pehaps u shud hav searched n got da result. But u posted n when god tuk out time for u. he sended help.
P.S. NEVER LOSE HOPE.
