Old 27-05-2005, 10:27 PM   #1 (permalink)
Default Problem With My Pc Please Help
I Recently Bought A Portable HardDisk Of 40gb Whose Speed is 480mbps and its USB2.0 Ready.
The Problem Is Whenever I attach the hardisk on my pc. My Pc Shutdowns By itself and not turning on till i remove the harddisk from the usb if i remove it. my pc works fine my windows also run as i again try to attach it the same problem starts and even my power doesn't gets on till the harddisk is plugged in my usb as i soon i unplug it then it works fine.
Pc Configuration
Mother Board : Asus P4P-800VM
Chipset : I865G
Proccessor : 2.4
4 usb ports(2 usb ports 2.0 compitable)
Hard Disk : 80gb
Cd Drives : Samsung Cdwirter And Sony Combo Drive
OS : Windows Xp Professional with Sp2
Please Help Me Out From this Please
sunil1982 is offline
Old 27-05-2005, 11:58 PM   #2 (permalink)
dinesh_singh
Posts: n/a
remover and reinstall the usb drivers and if problem exists pls check the hdd with any other system
Old 28-05-2005, 12:41 AM   #3 (permalink)
the problem is not with driver
its the cord or the connector on the casing which is faulty
this happen due to sorting of 1st and last pin
Happy Computing :lol:
krishnathelord is offline
