Old 14-12-2008, 10:10 PM   #1 (permalink)
Question DVD Writers malfunctioning!
I have a Samsung OCTROEDGE CD RW+DVD R and a sony DVD writer.
Recently I canceled a autorun process and after that the DVD writer has stopped functioning.........
It scratches the discs and doesnt read them..........
The same case is with the CD-RW which sometimes reads the DVDs.
Can anyone help........
I tried uninstalling the driver and then restarting the PC but it does not help.......
I tried disconnecting and then reconnecting the writers but does not help>...............
Any Help???????
visit:
http://skiewpoint.blogspot.com
http://aestheticblasphemy.blogspot.com
anshul is offline
Old 14-12-2008, 10:42 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: DVD Writers malfunctioning!
* Go for cleaning lens using Lens Cleaner CD/DVD
* If lens got misplaced you have to repair/replace it - For this you have to go to shop.
- MrinTech :)
mrintech is offline
Old 14-12-2008, 11:36 PM   #3 (permalink)
dinesh_mettur's Avatar
Smile Re: DVD Writers malfunctioning!
if u hav a warranty
go to shop n replace it
Dont give it to service center
___________________________
~~ THINK DIFFERENT ~~
.. U'r Ultimate Place To Enjoy ..
www.funisland.co.nr
dinesh_mettur is offline
Old 15-12-2008, 07:12 PM   #4 (permalink)
Question Re: DVD Writers malfunctioning!
but then why in the world would both of the lens decide to go bonkers at the same time...........
Can there be any software fault.......
a malware or virus??????
visit:
anshul is offline
Old 16-12-2008, 05:55 PM   #5 (permalink)
its impossible to be a software fault, and not possible that cancelling the autorun process, a fault could be created in the hardware... I think just some coincidence that these two problems happened at the same time...
Try cleaning ur lens, and if tht dosent work then go for a replacement.
Also did some power outage occur at the time ? Do u have a UPS and a surge supressor ?
Huzefa is offline
Pen drive malfunctioning Davidboon Hardware Q&A 6 28-11-2008 11:46 PM
Trillian Malfunctioning ~Phenom~ Software Q&A 2 08-12-2007 08:00 PM
dvd writers - Which one to buy ? CyCo Hardware Q&A 43 20-10-2007 11:56 PM
MP3 Player Malfunctioning Ajith Sen Hardware Q&A 3 02-12-2006 09:27 AM
