Old 27-05-2005, 08:00 PM   #1 (permalink)
trigger's Avatar
Default creating n/w with the use of parallel ports !!!!
hey frenz ,
cud u plz help me out of a prob. i wan to connect my pc to the LAN without using NIC. CAN it'll be possible??? can i do this by using parallel ports given ??? actually i've searched the net but i am not able to find out the solution to the prob..
plz help me out >>>>>
Are you watching closely?
trigger is offline
Old 27-05-2005, 11:13 PM   #2 (permalink)
dinesh_singh
Posts: n/a
coz there is no solution u cant do this
Old 28-05-2005, 12:41 AM   #3 (permalink)
QA Juggler
saROMan's Avatar
well bro..u cant..do with out NIC..unless there r only 2 PC's in network.....u will have to use a NIC...
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 28-05-2005, 03:49 AM   #4 (permalink)
c'mon man! .. U r trying to form a n/w without a n/w interface ....
Sir! it cant be done! sry!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
