Old 14-12-2008, 04:25 PM   #1 (permalink)
Elevating Humanity
The Conqueror's Avatar
Smile Upgrade Time...Please Suggest Components
Hi,
Its time now for me to upgrade my already old Pentium D PC...
This is my current system config:
nVidia 8600GT 512MB DDR3
Pentium D 2.4GHz
1GB DDR2 RAM
Intel Motherboard (NO SLi Support)
Please suggest components to upgrade my PC within Rs 30,000-Rs 50,000
Main Purpose - Gaming,Watching Movies..
Preferred Graphics Card Brand - nVidia ..Please dont suggest ATi Cards to me..
Thank you
Regards,
The Conqueror
The Conqueror is offline
Old 14-12-2008, 04:43 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Upgrade Time...Please Suggest Components
which mobo do you have and what are the components that you want to change???
desiibond is offline
Old 14-12-2008, 04:58 PM   #3 (permalink)
Elevating Humanity
I have the Intel D945GCR..
I want to change the Motherboard,Processor as well as Graphics Card and RAM...I am thinking of getting GTX 260 216 as graphics card..
Regards,
The Conqueror
Old 14-12-2008, 06:06 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Why don't you get only the GTX260 and if necessary, E7300(5.5k). wait for Deneb to come out. Let's say, wait for another 2 or 3 months.
If you are in a hurry,
1) Core i7 920 : 15k
2) ASUS X58 mobo : 14k
3) 2gig corsair 1333MHz DDR3 : 6k
GTX216 is a very very very good card that competes with HD4870. if you don't want to get into ATI tune, it's a good card. But I would say, wait for GTX295, which is going to be a dual processor GPU.
PS: It's really wise to wait a month or two.
Old 14-12-2008, 06:23 PM   #5 (permalink)
Elevating Humanity
Thanks..
I am planning to purchase in First or Second week of January
But I think it would be better to get 4GB DDR2 RAM instead of 2gb ddr3 , since the problem with ddr3 is high latencies and its very expensive as well..
As i have 17" LCD, My PC aint gonna support more than 1028*1024 Res.
Is GTX295 More powerful than 260GTX? I Think 1 Fast GPU would be better than 2 Slow GPUs ? Same goes for processor...
I am ready to wait till Jan 12...I want to get it soon coz my 8600GT makes a lot of noise,its so much that it produces more sound than my game audio haha.I have used my currect pc to maximum extent for over 3 years.
Regards,
The Conqueror
Old 14-12-2008, 06:35 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^^ Did you check HD4850X2?? It is competing with GTX280 and HD4870 X2. Performance does not depend on clock speed. It depends on architecture.
A 1.6GHz Core2Duo easily beats a 3.2GHz Pentium 4 processor. Why? core2duo is 50% slower when it comes to clock speed. It's the architecture and parallelism.
Better wait till mid January.
Old 14-12-2008, 06:37 PM   #7 (permalink)
Elevating Humanity
Yeah , My Pentium D beats core2duo of my friend ...
So which is the Most Powerful Graphics card atm? GTX 280? or HD 4870X2?
Regards,
The Conqueror
Old 14-12-2008, 06:41 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ Pentium D is a dual core processor isn't it.
And HD4870X2 is the current market leader, isn't it?
and seriously, which core2 processor is your Pentium D is outperforming???
is that after overclocking?? If yes, what happens if you overclock core2 to the same extent?
Old 15-12-2008, 12:12 PM   #9 (permalink)
Elevating Humanity
it was an entry-level processor
And Does HD4870/260GTX Make any noise?????? Please I want a silent card, I've been living with high noisy 8600GT for more than 1 and half yrs and i want to play games in peace
Regards,
The Conqueror
Old 15-12-2008, 12:46 PM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
how about this card: http://global.msi.com.tw/index.php?f...6&prod_no=1489
MSI Says: MSI 3-in-1 High Efficiency Fan
MSI high efficiency fan radiator comes with a heat-pipe, heat-sink and fans. The high-tuned and integrated 2-slot design implementation, not only decreases the GPU temperature rapidly, but also delivers whisper-quiet cooling and ensures quiet operation.(Optional Feature)
Old 15-12-2008, 03:32 PM   #11 (permalink)
Elevating Humanity
Nice..thx any link for the Silent 216 Core ? ....anywayz whts the street price of i7?
Regards,
The Conqueror
Suggest the best components under 11k saqib_khan Hardware Q&A 3 08-01-2008 10:27 PM
[SUGGEST] Components for a 10k pc (only mobo, processor, cabinet, hdd) aku Hardware Q&A 4 27-09-2007 08:44 PM
Is This The Right Time To Upgrade??? caleb Gamerz 44 26-10-2006 06:15 PM
