Old 14-12-2008, 03:26 AM   #1 (permalink)
Arrow copying Hard Drive To DVDs? Plz Help
I want to Copy my Hard Drive to optical media (such as DVDs). I want to copy every bit of information (even EMPTY clusters & sectors). I have deleted some files from the hard drive and am planning to recover them later. Can I COPY Hard Drive to DVDs (including empty clusters & sectors). Which software to use and how to do this? plz help immediately!
RajivKumar123456 is offline
Old 14-12-2008, 10:01 AM   #2 (permalink)
Extheist
aditya1987's Avatar
Default Re: copying Hard Drive To DVDs? Plz Help
Norton Ghost will do it for you.
Meowww......
aditya1987 is offline
Old 14-12-2008, 12:24 PM   #3 (permalink)
Norton Ghost/Acronis trueimage will help
ThinkFree is offline
Old 14-12-2008, 05:24 PM   #4 (permalink)
Arrow Re: copying Hard Drive To DVDs? Plz Help
Thanx Aditya & ThinkFree! BUT I have already tried these softwares but can't understand how to do this job (in Norton Ghost) please GIVE me appropriate tutorial on doing this. AND if you gonna suggest any software ONLY suggest FREEWARE & Light weight (because I'm a dial-up user) OR any software available on Digit Disks.
Old 14-12-2008, 07:23 PM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
You need 2 hard disks if you want to do that.
dheeraj_kumar is offline
Old 14-12-2008, 08:05 PM   #6 (permalink)
In a New flavour
Most Wanted's Avatar
^^hey, he want backup on optical media such DVD. Buying a new hdd may be more costly than DVD. I think ghost is best for this.
Life Grows Best, When Deciplined
Most Wanted is offline
Old 15-12-2008, 07:23 AM   #7 (permalink)
paroh's Avatar
Acronis.True.Image can do this but as u said u want to make backup of even the even EMPTY clusters & sectors by this if u have 20GB hard disk the image will be also of 20GB containg also the clusters and sectors
paroh is offline
Old 15-12-2008, 07:24 AM   #8 (permalink)
^^ Read his question again. He wants to backup every byte in his HD. So his backup file would be the size of a hard disk. Where would he store it? in another hard disk, of course.
Old 15-12-2008, 03:39 PM   #9 (permalink)
^^But still buying DVDs would be cheaper(though very time consuming) than buying a separate hard disk.
Old 15-12-2008, 04:49 PM   #10 (permalink)
^^ True, but How would he write each byte directly to the DVD, without making a seperate file? Thats impossible, every burning software needs some sort of buffer to read from. When you're taking backup of the whole drive, you dont have any space for buffer.
Old 15-12-2008, 05:05 PM   #11 (permalink)
See if these help
http://www.raymond.cc/blog/archives/...-norton-ghost/
http://www.macrium.com/blog/2008/03/...umReflect.aspx
Old 15-12-2008, 05:50 PM   #12 (permalink)
^^ I dont think they would, because:
1. "I want to copy every bit of information (even EMPTY clusters & sectors)." Nope, this doesnt.
2. "I’d advice you to create another partition (E: drive) to save the backup image." You need a place for the backup.
Old 15-12-2008, 06:09 PM   #13 (permalink)
din
Tribal Boy
din's Avatar
Whatabout DriveImage XML
din is offline
Old 16-12-2008, 01:23 PM   #14 (permalink)
Yes, it doesn't copy every sector but backup can be saved on discs
Reflect can store images on one or many DVDs but it is far better to choose a local or network drive. By using a local or network drive you can easily access your image files for restoring and you can browse your images in Windows explorer. This isn’t possible if the image file spans more than one DVD.
Old 17-12-2008, 06:57 PM   #15 (permalink)
Yeah, I saw that. Anyway, its OP's call. Let him choose
Need to encrypt the DVDS for copying!!! tyreads Chit-Chat 3 26-04-2008 09:18 PM
copying files become slow in my usb drive thecreativeboy Hardware Q&A 4 30-06-2007 05:02 PM
DVD Drive not reading CD DVDs.. plz help.. medigit Hardware Q&A 2 18-03-2007 02:46 PM
help needed on copying a dvd video to hard disc san85 QnA (read only) 14 12-08-2006 07:48 PM
dvd drive not reading all dvds gauravcreations Hardware Q&A 2 06-12-2005 11:38 PM
