guys n gayols
i m unable to play a vcd on my comp
while its running on my dvd player
it shows nothing in cdrom
earlier also i was unable to play a vcd once same problem
well i want to know some way to play them n convert them to vcd
should i use isobuster
i have all good to bad media players
Right click on the cd rom drive open it.Search the folders inside one of them u will find a avseqo1.dat and so and so right click on them open with windows media player or any video player of ur choice
it shows two things....
either ur cd is empty or you its been wrriten in a wrong way...
so the only way to run is to run it manualy.....as mr shrek said.
I think the format is different. I have some dvd's that play on my computer but will not play in the dvd player. It might be the same thing but the other way around.
Quote by Garfield'
right click your dvd drive and click the volumes tab if the tab is blank than it is possible that the cd is blank or is not been read by your drive properly.
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
