Huh?
There's a big difference between a siren and a beeping sound.
If it's beeping, tighten all your components to the motherboard (RAM, CPU, drive cables, etc.). Though a loose CPU or RAM chip would almost always give you a blue screen, it might be a loose HDD cable, so check both ends (on the MoBo and also to the HDD).
If it's a siren sound and it decreases when you lower the speaker volume, and increases when you increase it, it could be a software sound. Check to make sure that system speaker is unchecked in the advanced volume properties. Have you installed any software, anti-virus or anti-spyware? Perhaps it is a warning tone from such software.
Specify exactly what sound it is (beeping or siren) and if it's a beeping, count the beeps (2 long beeps, or 1 looooong beep, or 3 short beeps, etc.) and post here.
Raaabo
This Forum has rules:
Read them, or else!
Compute Rig: Phenom II X6 1090T | Crosshair IV Formula | 8 GB HyperX DDR2 | XFX HD 6850 | 2 x 300GB Velociraptor (RAID 0) + 1.5 TB Barracuda | Win Pro 64
HT: Denon 1912 | Jamo S608 HCS 3 | Jamo Sub 300 | PS3 | TataSky+ HD | Philips 32PFL5609/98
ICE: Sony Xplod DSX-S100 | Sony Xplod XM-GTX6020 | PowerBass S-12 | 4 x Blaupunkt IC (doors) | 2 x Alpine SPS-609 (rear-mounted)
Guitar Rig: Slammer CT 212 Metallic Red | Yamaha Pacifica PAC012 | Line 6 Pod X3 Live | Beta Aivin MX 30 | Marshall MG 15 CD | Korg ToneWorks AX100G
