Old 05-09-2004, 03:32 AM   #1 (permalink)
Default oxygen phone manager !!!!!
why doesn't oxy phone manager 2 recognize my nokia 3200?
manmay is offline
Old 05-09-2004, 07:35 PM   #2 (permalink)
hmmm
well maybe ur using an older version of the software
and ur cell was released later
update ur software
No Mercy, No Limits.
theraven is offline
Old 05-09-2004, 10:58 PM   #3 (permalink)
Oxygen phone manager, atleast the newer version supports Nokia 3200. You should also try to connect another phone with your datacable, maybe that is at fault.
wORm is offline
Old 05-09-2004, 11:13 PM   #4 (permalink)
un
Plz chk the datacable connection! Also in option dialog box select the apporiate option i.e, for USB Cable its DKU5 and for COM Cable its DLR3
un is offline
Old 05-09-2004, 11:22 PM   #5 (permalink)
ya i was using the older version of the software.
i dloaded the new version and the work was done.
thnx guys for your responses..
manmay
manmay is offline
