Old 27-05-2005, 12:44 AM   #1 (permalink)
Default NTFS Premission problem
I have windows XP installed and the Drive C (system drive) is NTFS. I have protected the My Document folder (using access grant system) so that only me (administrator) can open the folder
Now my system was unstable so i have reinstalled winxp. I have backed up the my documents folder in D drive (NTFS). What i forgot was that i forgot to remove the permissions. So now on my new win xp installed i cant open the my documents folder. Any way to solve this problem?
valtea is offline
Old 27-05-2005, 01:19 PM   #2 (permalink)
expertno.1's Avatar
if u have reinstalled xp
tell whether u have formatted the hard drive or not
(c
if not
then the username was what ?
if yes then the username has no relation
i know the problem
first tell me ur old username and ur new username(i.e after reinstalling xp)
expertno.1 is offline
