Originally Posted by rohanbee
cpu and then 17" monitor.........i had my altec's on the ups but that had to be removed as the power definately not enough.
Now when the power comes back up everything gets switched on together so obviously the requirement is more for power as everything switches on immediately so one thing always gets switched off...in my case the monitor..
Originally Posted by pimpom
Please provide as much detail as you can. What type/VA UPS, your config and that of the other computer, history of usage, etc. For example, did you upgrade or add something to your config when you changed the SMPS ?
Ok, Now let me tell you that as rohanbee has already stated, its a UPS problem it seems, like he said his monitor goes off and On again when a power cut happens suddenly. And this is what is exactly happening with my Computer as well.
Now as far as pimpom request goes, let me provide you all with more details.
Note :I will refer my old system ( 300 watts SMPS) as
SYS 1.
and my new system (400 watts SMPS) as
SYS 2. Herein after.
Ok I have this
SYS 1, which has the Gigabyte mobo (P4), Pentium 4 processor 2.4 Ghz, 128 MB RAM, 15" Monitor, Modem, No Graphics Card, One HDD 80 GB, CD-Rom drive, CD-RW Combo drive, Keyboard, Mouse, Altec Lansing Speakers.
I use a UPS 600 VA with this
SYS 1 without any problem.
Then I have this
SYS 2 Which I bought recently, Which has Intel Original Mobo D915GAV, P4 3 ghz, 512 MB RAM, 15" Monitor, Modem, No Graphics Card, one HDD 80 GB, CD-RW Combo Drive, Altec lancing Audio System 6.1 channels, Keyboard, Mouse ( see my signature for more details)
I use a UPS 600 VA with this SYS 2 with system restarting during a power cut as mentioned above.
Now , let me know your suggestions.
