Old 10-12-2008, 10:35 AM   #1 (permalink)
Exclamation some more question
hi geeky guys here plz help me on these points also
i am having C2D 2.66 with 4 gb ram n 250 gb hard disk n window xp sp3 installed on it
1. when ever i click shut down/restart every application got closed but not my window....at this point only my wallpaper remain there and desktop icon's are also gone..,but shut down screen didnt appear....then i have to press manual reset button and then log off screen appear and computer shutted down...there is no error and at that time when only my wallpaper is there i pressed ctrl+alt+del to see what are the process running there i find nothing suspicious and even memory used and processessor too gone zero...i am using tune up utility 2009 and quick heal but it too didnt identify any error
2.i am using lime wire for downloading some torrnt file ...i used to get maximum speed during night so i thought that turn monitor off in 5 minute to save power consumption but after it i noticed that during this download speed became very low i.e 2-5kbps but when i turn on monitor i get 20-25kbps...i wana know what to do so that i can turn off my monitor and still get that high speed
3.i have installed acronis disk director suite trial version from its site but its getting hang on its installation or during 1st run and then i have to reinstalled it again n again...how to know what prob is making him not to start or hang continuously and then whenever i click on some other prog to uninstalled it gave me error that some changes ar pending for acronis click here to un do it and when i did it acronis get corrupted...what happening??acrosnis is not for window xp sp3????or i should switched back to nortan ghost??
3.tell me or give me a detailled tutorial for nortan ghost/acronis for making bootable recovery disk...i wana make back up of my OS(window xp) as i have heard in some forums that it give you iso image which can be used to restore back your operating system in 4-5 minutes...plz tell me how to do that...is it true that we can do this as what i am thinking..like i 1st install my os and update it fully and then installed my fav software on it and then i should make an image on the cd/dvd and when ever it give me problem i just have to insert my that cd/dvd and within 4-5min my OS is repaired and i dont have to wait for all the process like formating/installing window/driver and software and all
4.I am using Sun Java Virtual Machine version2 on Win Xp SP3 (with 10 GB hard disk and 1 GB RAM allotted to it).
i have installe window xp in it n I have shared a software folder in the d drive instead of this machine folder but after starting the window I am unable to find that software folder. How to use that folder in the virtual machine? OR tell me how to test unknown software in Virtual machine of which installer is kept in my hard disk.
5.i am using dvd decryptor to copy my dvd on my hdd into 1 single .vob file then i am forced to use auto gk to convert them into avi but as i like to watch movie in my n 95 so i had to convert them into mp4 format....it takes time...i dont need 700 mb rip now .....i want to avoid that auto gk phase n directly convert that large .vob file to mp4 by total video converter but dvd decryptor has one limitation/bug that it show total time of movie very low as i found out that it show the time of only 1st .vob file this make TVC to convert whole file till that time only
for example if actual movie is of 2 hr and file created by dvd decryptor is just 50 min then TVC will convert file upto that time only.....how to over come that problem
5.can anyone guide me how to shoot best movie via mobile(n 95) as i have heard about mobile movie making contest so wana know basic aspect of these
ashishstillthere is offline
Old 11-12-2008, 07:03 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: some more question
1. Defrag your hard disk, use http://www.ccleaner.com/download to clean junk and if possible clean your system RAM
2. Nothing it depends on the number of seeders. There is no immediate connection between torrent speed and turning off monitor.
3. Use Norton Ghost. Norton Ghost tutorial: http://www.google.com/search?hl=en&q...orton+ghost+tu
4.Sorry
5.Sorry
Others Might Help you too
Cheers!!
- MrinTech :)
mrintech is offline
Old 11-12-2008, 07:29 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
4. Install VirtualBox Add-Ons from the first menu, whatever its called.
2. No connection at all. Torrent speeds are highly unstable.
And you better reinstall windows.
dheeraj_kumar is offline
Old 12-12-2008, 10:27 PM   #4 (permalink)
means???there are no such options
why???is there any other way
Old 12-12-2008, 10:50 PM   #5 (permalink)
Wise Old Mouse
mrintech's Avatar
Nope your OS has been corrupted badly. You have to format it again... No other option.
I am saying this because previously your PC was badly infected, this may have damaged many files and made OS unstable.
- MrinTech :)
mrintech is offline
Old 12-12-2008, 11:12 PM   #6 (permalink)
hey mrinmay ....i have already get it formated with a new xp sp2 and the made it sp3 via digit dvd and now i have KIS 2009 and usb guard to protect me...so now tell is there any other options
Old 12-12-2008, 11:17 PM   #7 (permalink)
Wise Old Mouse
mrintech's Avatar
Follow these things:
* Defrag your PC every fortnight or after some constant installations. You can go for: http://www.auslogics.com/disk-defrag
* Remove unuseful startup programs.
* Clear Junk using: http://www.ccleaner.com/
* Try to clean your system RAM
* If still your system is sluggish revert back to SP2
Cheers!!
- MrinTech :)
mrintech is offline
Old 13-12-2008, 12:42 AM   #8 (permalink)
i think it depend upon turning up coz i just noticed that in lime wire connection status it was displaying waking up when i move my mouse to resume monitor till then speed was 1kbps and seeder were 6 and the just in a minute speed reached 29kbps n remain constant for that
so vat could be the problem..i have done setting via ryte click->properties->turn off monitor in 5 minute
i dont have problem of window start up i have problem in shutting down as it need to be manualy i have 4 gb ram so i cant say it will be due to ram
i am already using cc cleaner and tune up 1 click maintaince take care of drive defrag and temporary file also
Old 13-12-2008, 12:47 AM   #9 (permalink)
Wise Old Mouse
mrintech's Avatar
Try: http://azureus.sourceforge.net/
- MrinTech :)
mrintech is offline
Old 14-12-2008, 01:49 AM   #10 (permalink)
4. Devices->Install Guess Add-Ons.
2. Monitor and torrents have absolutely no relation. You can still eat with your eyes closed, cant you? Configure your utorrent properly, check the tutorial section.
Old 14-12-2008, 11:28 PM   #11 (permalink)
thanks dheeraj for that virtual box now i am able to do that but i am using limwire turbo 4.18 so how to configure it
Old 15-12-2008, 07:26 AM   #12 (permalink)
I dont use limewire, turn on the scheduler, that should do it. Someone else who uses it can probably post some tips.
Old 15-12-2008, 09:03 AM   #13 (permalink)
thanks now i am waiting for some one who use lime wire
C & C++ question n2casey Programming 16 05-03-2007 01:23 PM
HDD and OS Question shwetanshu QnA (read only) 10 07-02-2006 01:33 AM
question Akhil Jain QnA (read only) 19 31-05-2005 01:58 PM
SLi rig question godzi_85 QnA (read only) 26 24-05-2005 05:55 PM
