10-12-2008, 09:11 AM
Traceur
PC takes 9 minutes to start...
Everything was going fine until yesterday night. I woke up today and started my PC, just to find out that it won't. I got an error message saying "C:\Windows\System32\System" file was missing.
I had to check my Orkut scraps, so I started my PC using a Linux Mint live CD. After doing all that, I turned the PC off, then again after sometime I started it, but now even Linux refused to start.
Then I called one of my friends and asked him to bring his Windows XP CD. Even during the installation it was taking a lot of time. Now after reinstalling, the PC takes approximately 9 minutes to start. What should I do now???
Parkour: A journey started by two & followed by many...
10-12-2008, 09:40 AM
It doesn't matter!
Re: PC takes 9 minutes to start...
Do the basics,
Run an antivirus, anti-malware scan.
open msconfig and untick unwanted programs from startup..
Run any tuneup utility..
Even try disk defragmentation. .
Reason: Automerged Doublepost
10-12-2008, 10:17 AM
try installing xp on a different drive.
Evil Lives 4ever......
10-12-2008, 10:30 AM
Traceur
ok, but the problem even persisted when I disconnected the Hard-drives and only used the CD ROM to boot Linux...
11-12-2008, 08:27 AM
then most prbbly u hv too much uwanted expired entries in registry. n also keep less applications in start up.
dwnlod ccleaner. run registry fix n remove unwanted applications frm start up
finally scan ur system
d a m n ! !
11-12-2008, 12:35 PM
Bond, Desi Bond!
1) Check IDE cables.
2) Check if CPU is getting adequate airflow.
3) What is your system's config?
11-12-2008, 12:40 PM
Tech'ing life seriously!!
yup... please post ur PC config.
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
11-12-2008, 12:48 PM
Wise Old Mouse
clean your system RAM
11-12-2008, 03:39 PM
Traceur
AMD 3000+, MSI K8M800, 80GB PATA+ 250GB SATA, 512 MB DDR 400 MHz...
Now its taking 30 to 45 minutes to start...!!!
Forgot to mention 1 important thing, this thing started after I installed Windows XP Manager software and did some cleaning of XP with it.
That software actually removed some system files (as I have mentioned above). I had to reinstall XP, but even the XP's CD took a lot of time just to load, I mean I have installed XP on my PC and also on many other PCs for more than a 100 times. It never takes so much of time, I am very confused right now, I guess there is some problem with the hardware only...
11-12-2008, 03:55 PM
Bond, Desi Bond!
put your hdd in any other pc and try to install windows in your HDD.
There is also a h/w diagnosis in Everest Ultimate I think, run it and paste the report here.
11-12-2008, 04:08 PM
IronMan; Ready to Roll...
I think there's something wrong with IDE channels.. maybe something in BIOS? Okay, HDD maybe the sole culprit; but then why would'nt Linux Mint not boot the second time he tried it, that too with HDD disconnected?
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
11-12-2008, 05:19 PM
check ur cpu fan.
11-12-2008, 05:31 PM
Bond, Desi Bond!
Reassemble everything and check!!!
12-12-2008, 03:27 PM
Always confused
Brother RAM will automatically be erased when no power is supplied i.e when shutdown.
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
12-12-2008, 05:08 PM
AFK
Check proper airflow of the cabinet and ensure all the cables are connected properly.
I had a similar prob (8-10 mins of booting time). I reassembled my PC and it came down to about 4 mins. But that was 2 years ago
12-12-2008, 06:14 PM
Traceur
OK, I will check the hardware, but after a few days. Because I have my presentation on Monday and I don't want the PC to stop working, in-case something goes wrong!
Search this Thread |
