Old 07-12-2008, 10:41 PM   #1 (permalink)
Question Please Help Me
in the morning...somebody gave me some file to install in the system...(something called GMAIL PHRACKSTER)...after installing it... everything from my desktop vanished along with quick launch icons. however, the hard disk shows that every data is in its place but when i try to search it, i don't get anything...can anyone tell me what has happened and what i should do now...??
mayank292 is offline
Old 08-12-2008, 01:10 AM   #2 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
Default Re: Please Help Me
Virus? Try some antivirus like AVG or Avast. It may not get installed.. you may face tough time fighting if its a virus..
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 08-12-2008, 01:16 AM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
To the OP:
tat sumbody wud probably must be ur friend..(im guessing) or better worse, brother of ur gf, jus joking ) y did u install such a s/w dude..
--- i feel sorry for u... for the hassels caused in cleaning ur system...
neways, wat AV u have ??? use AVG (as IronMan) said or use NOD32 or even Kaspersky, also , to remove any reg entries (tat must hv been SURELY been created by tat s/w) use XP Tools Pro and SuperAntiSpyware (believe me, its way better than any adware cleaner like lavasoft's ad aware too)...
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 08-12-2008, 01:28 AM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
Also a-squared: http://www.emsisoft.com/en/software/free/
- MrinTech :)
mrintech is offline
Old 08-12-2008, 11:21 AM   #5 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: Please Help Me
Launch "task manager", check if u c any process is running which u don't recognize. End it.
If not able to do this.
Restart ur PC and boot into "Safe Mode", try to uninstall any crapware u've.
Install a good antivirus (I would recommend any AV which provides boot-time scanning, Avast and Quick Heal would by my choice)
Restart and and do a boot scan.
From next time, don't install/unzip/open any folder without running a virus scan.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 08-12-2008, 01:18 PM   #6 (permalink)
Question Re: Please Help Me
i have Avast Anti-Virus and would you mind telling me what is XP Tools Pro and where can I get them??
Besides that i have used SuperAntiSpyware but nothing really happened... the situation still persists.
also, it happened in Windows Vista...so can any one tell me how to approach about it when it comes to Vista.
Old 08-12-2008, 08:59 PM   #7 (permalink)
well XP Tools pro is a s/w to remove unwanted reg entries created in ur Registry, jus scan the registry and delete all the unwanted entries, its like apiece of cake adn it really works (say for eg, u hv been trying to install a s/w even after resttarting ur system but still there si an error abt corrupted files) then XPtools pro does the job..
google it for the same... its a relaly small app of jus approx. 8-10mb
but 1st u need to scan ur system (NOT with avast plaese....) but with eiter AVG or NOD32 or Kaspersky..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
