Old 07-12-2008, 05:32 PM   #1 (permalink)
Default partition on pen drive
hi , friends
i have 32 GB pendrive , i want to create partions on it , how can do the same?
pl . help me
Thank you
BHAVESHp is offline
Old 07-12-2008, 05:55 PM   #2 (permalink)
Default Re: partition on pen drive
A 32 GB pen-drive, bah! Just curious did you have to import it from abroad or is it available in Indian market?
Coz just yesterday i got a Transcend 8 GB one, good to go with Portable Apps . Never heard of 32GB in Indian market at least.
markupdude is offline
Old 07-12-2008, 06:16 PM   #3 (permalink)
Wise Old Mouse
mrintech's Avatar
Dude Frankly speaking don't go for partition. Suppose you partition the drive into 4 slots, maybe after some time Windows fails to detect any one of them (I said May Be).
So I suggest don't go for partition at all.
- MrinTech :)
mrintech is offline
Old 07-12-2008, 07:51 PM   #4 (permalink)
Linux all the way
ya what he said is right, windows doesnt detect partitioned pendrives.
I had partitioned my pendrive in linux, linux detected it, but wiindows didnot detect all the partition.
just the first partition.
At times life takes a U turn and you get back where you were...
Vishal Patil is offline
Old 08-12-2008, 06:45 PM   #5 (permalink)
thank u buddies for your response
bhvesh
BHAVESHp is offline
Old 08-12-2008, 08:26 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
... so what happens?
Thats purely untrue. Maybe something to do with you alone. If its not working for you then don't generalize for everyone.
I always use a partitioned flash drive if its above 2GB in size. Helps me organize my data well. It has also so happened that some portion of the flash drive went bad and fortunately I lost data only in that partition as opposed to all data. From my experience I'd say there were no problems at all (preferably make FAT32 partitions).
infra_red_dude is offline
Old 08-12-2008, 09:02 PM   #7 (permalink)
din
Tribal Boy
din's Avatar
After I bought new HDD for my laptop, I put the old HDD in casing and use it as a USB drive, (of course not exactly a pen drive - but the interface remains the same) and all partitions were detected by Windows without any problem. I do not think partitioning pendrive is a problem.
din is offline
Old 08-12-2008, 09:27 PM   #8 (permalink)
Wise Old Mouse
mrintech's Avatar
Actually I want to say that if Windows fails to detect it than it fill inadvertently leads to data loss.
Also suggest freeware for partitioning Pen Drive apart from DIsk Management
- MrinTech :)
mrintech is offline
Old 09-12-2008, 03:06 AM   #9 (permalink)
Wire muncher!
I'm sorry I still don't get what you are trying to say.
Never had to use any other partitioning software other than Disk Management on Windows. Works like a charm!
Old 09-12-2008, 09:10 AM   #10 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
My Disk Management Doesnt have any option to Partition Pen Drive. Am i Missing something ?
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 09-12-2008, 09:52 AM   #11 (permalink)
Wire muncher!
Disk Management will not directly allow you to partition. You need to flip the Removable Bit by some utility (like BootIT or HP etc.). The flash drive can then haf multiple partitions.
Old 09-12-2008, 11:32 AM   #12 (permalink)
Host4Cheap.org
Thanks infra
Shall try
Somehow the BootIt Flip doesnt work on 3 Pendrives
Last edited by Sukhdeep Singh; 09-12-2008 at 12:04 PM. Reason: Automerged Doublepost
Old 09-12-2008, 12:24 PM   #13 (permalink)
din
Tribal Boy
din's Avatar
After a 'detailed look' this is what I understood !
Actually I want to say that if Windows fails to detect it, then it will lead to data loss.
And google aunt took me to this link - Partitioning a pen drive??
din is offline
Old 09-12-2008, 10:36 PM   #14 (permalink)
Wire muncher!
^^^ Ok.. I get his complete sentence now
Old 10-12-2008, 05:54 PM   #15 (permalink)
Wise Old Mouse
mrintech's Avatar
It was a Typo... It must be will
- MrinTech :)
mrintech is offline
Old 10-12-2008, 07:01 PM   #16 (permalink)
TheSaint
NucleusKore's Avatar
Use GParted
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 11-12-2008, 01:02 PM   #17 (permalink)
Tech'ing life seriously!!
sude's Avatar
windows ;does detect pqrtitioned pendrives...
i have an transcend 2gb pendrive which i have partitioned with Transcend mFormat utility.. and it works fine...
Sude
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Formatting External Drive Partition hitman050 QnA (read only) 2 13-08-2007 06:32 PM
Partition hard drive abhi_10_20 QnA (read only) 2 29-07-2006 11:32 AM
How To Create Partition On OS Drive s18000rpm QnA (read only) 2 14-07-2006 09:44 AM
Please help me partition my drive devilhead_satish QnA (read only) 3 25-08-2005 10:07 PM
