Old 06-12-2008, 11:28 PM   #1 (permalink)
Unhappy Rapidshare Problam
while i am down loading from rapidshare i am getting allways tis error
Your IP address 218.248.68.115 is already downloading a file. Please wait until the download is completed
Plz tell wat i must do
praneeth is offline
Old 06-12-2008, 11:41 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: Rapidshare Problam
Rapidshare don't support multiple downloads at one time for Free Users. If you are downloading a file than you can't download another file simultaneously. Let the first download be finished than wait for 14 Minutes and than go for second download.
Also remove your IP Address from the above post
- MrinTech :)
mrintech is offline
Old 07-12-2008, 12:25 AM   #3 (permalink)
Alive Again...
satyamy's Avatar
if you download using Free Account Type you will face this because Rapidshare dosent allows Multiply Download to Free Users
you need to get a Premium Account to get more than 1 Downloads Simultaneously
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 07-12-2008, 01:12 AM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
also, if ur d/load was stopped midway (maybe coz of a connection failure) and then if u try to restart the d/load u are bound to get the msg:
Your IP address xxx.xxx.xx.x is already downloading a file. Please wait until the download is completed
to solve this, connect to the net and jus remove the power cord from the back of the router (with the router being still connected to the net) and re plug it in after jus 1 sec so that u are again connected to the net (wen the status/adsl light blinks) then DC ur net and re connect again and then d/load via RS (rapidshare)...
CHeers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
RapidShare To RapidShare thetillian QnA (read only) 5 09-06-2008 10:15 PM
Help me with Rapidshare!!!!!!!!!!! davinci QnA (read only) 1 29-09-2007 01:33 PM
RapidShare niks999 QnA (read only) 1 31-12-2006 03:14 PM
Rapidshare godsownman QnA (read only) 6 04-01-2006 04:21 PM
Rapidshare ! ! ! ax3 QnA (read only) 4 08-12-2005 09:38 PM
