well bro the Ideal solution is to have Two Fans ..1 that Sucks air in and Other That throws the hot Air Out......also chk if ur cabinet is cluttred with Hanging Cables etc ....keep some room in the Cabinate for Flow of Air in it...
actually i have two pcs 1 with original WinXP home edition came with compaq PC , other Pirated XP professional , SP2 doesnt install on it as it says that the key used for installtion is not valid. So , can i use my Compaq key , More, recently i used a software to find key that was used to install my Compaq PC , it is different from the key pasted on front panel of cabinet , so i have got 2 keys.
1st thats bkoz u mentioned u have a Pirated ver ..so Sp2 will detect it and wont install....There are ways to deal with it..but its not ethical to talk here
2nd No u cant use ur Compaq key..as its for Home edition..and wont apply for the Proff edition ....you will need the Proff ed Sp2 key to install Sp2 .....
what exactly u mean by 2 keys ????? did u used the Key on the front panel of cabinet to install Home ed ?? if u ddnt then u will have 2 diff keys ....but if u did....then may b the soft is showin the key in other format
eg : insted of ABCDE-FGHIJ.......
its showin 1234-xxxxxx etc
is it right???
