Old 05-12-2008, 03:08 PM   #1 (permalink)
sushan's Avatar
Cool Pen drive Ejection Error
Dear frens,
I have a problem with a pen drive which says " Ejection error" and i had to plug out
necessary solutions is appreciated.
thanks
HrD 2 tackle TeCHH ProbLemmS
Free Latest gadjets at http://www.xpango.com?ref=92545037
sushan is offline
Old 05-12-2008, 05:55 PM   #2 (permalink)
paroh's Avatar
Default Re: Pen drive Ejection Error
some application is using ur pen drive end that task from the task manager first to use the save and remove feature
paroh is offline
Old 05-12-2008, 06:08 PM   #3 (permalink)
sushan's Avatar
what is save and remove feature?
sushan is offline
Old 05-12-2008, 06:43 PM   #4 (permalink)
"Aal Izz Well"
Krazzy Warrior's Avatar
I prefer (Note:Only in this case when it gives error) to shutdown the PC--> take out the pen drive---> On the pc....
http://twitter.com/krazzywarrior
Krazzy Warrior is offline
Old 05-12-2008, 06:52 PM   #5 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: Pen drive Ejection Error
Do you mean Safe Remove
it happens many time
like if you made a word document than you close that document & save it on your Pen Drive & try to remove but it give Ejection Error
because your MS Word is Still open (though your File is closed) but if the application is open sometimes it wont remove easily
also many time we close the application but it Runs in Background
so open Task Manager (if you r in WinXP or Vista),
Click on Process tab and see if any programme you were using (like MS Word in this case) is still running in background
if it is running than right click on it and click "End Process"
than try to remove your Pen Drive
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 05-12-2008, 10:18 PM   #6 (permalink)
asia://india/ka/bangalore
a_to_z123's Avatar
If you face any errors like these:-
Cannot delete file: Access is denied
There has been a sharing violation.
The source or destination file may be in use.
The file is in use by another program or user.
Make sure the disk is not full or write-protected and that the file is not currently in use
Use UNLOCKER!!
Very small and handy software... Just right-click on the pen-drive icon in My Computer and select 'Unlocker' to unlock all handles...
:) I've got my F, C and K . Now all I need is You !!! :)
a_to_z123 is offline
Old 06-12-2008, 12:58 PM   #7 (permalink)
sushan's Avatar
guys it doesnot solve my problem
sushan is offline
Old 06-12-2008, 01:06 PM   #8 (permalink)
Alive Again...
satyamy's Avatar
than possibly their is Virus in your System
try Kaspersky Internet Security to find & remove viruses
(if you dont have Licensed Version try 30days free trial pack)
http://www.kaspersky.com/trials
satyamy is offline
Old 06-12-2008, 01:20 PM   #9 (permalink)
Wise Old Mouse
mrintech's Avatar
also scan with: http://www.superantispyware.com/download.html
- MrinTech :)
mrintech is offline
Old 06-12-2008, 01:25 PM   #10 (permalink)
sachin_kothari's Avatar
kill the explorer process in the task manager. then manually create explorer.exe. now try removing the pen drive normally. it should be able to eject safely.
sachin_kothari is offline
Old 21-12-2008, 11:22 AM   #11 (permalink)
my name defines me
cyber's Avatar
backup all the files stored on ur pendrive and format it
cyber is offline
Old 21-12-2008, 12:02 PM   #12 (permalink)
Section Moderator
gopi_vbboy's Avatar
i think ur pendrive doesn feel like ejecting out..kinda addict i think....jus kidding
how do u ask such q's without specifying ur os or pendrive name or ur ocnfig?
gopi_vbboy is offline
Old 21-12-2008, 12:05 PM   #13 (permalink)
Deadly Creature Me!
ubersoldat's Avatar
Use Avast 4.8 and scan ur pendrive for malware and viruses. Use winrar and open ur pen drive and check for any Autorun.inf file. If it exists then delete it. Hope this helps.
@satyamy and mrintech. I don understand why u guys recommend Kas and SuperAntispy. I suggest Avast for its realtime protection which detects viruses and malware instantly. Any specific reason to use KAS or SuperAS?
ubersoldat is offline
Old 22-12-2008, 12:52 AM   #14 (permalink)
Alive Again...
satyamy's Avatar
the main reason is as compared to other KAS has the strongest and biggest Database
and other reason are -
its interface is very nice, uses less system resource and you can get it at very cheap cost
satyamy is offline
Old 22-12-2008, 12:57 AM   #15 (permalink)
Wise Old Mouse
mrintech's Avatar
Because SuperAntiSpyware has got the highest detection rate among all freewares: http://www.techsupportalert.com/best...re-remover.htm
Also this is a nifty utility for removing malwares/scumwares/adwares/trojans that other AV softwares fails to detect sometimes
You can never trust Avast or a single AV Freeware at all instances
- MrinTech :)
mrintech is offline
Old 22-12-2008, 04:19 PM   #16 (permalink)
Deadly Creature Me!
ubersoldat's Avatar
Talking Re: Pen drive Ejection Error
Hi mrintech and satya, thanks for the reply. Not tryin to defend myselves but KAS is paid AV no? Thats why I told. Dont feel bad guys . Mrintech is my best friend .
@gopi, whats there to laugh u dumb moron?
Old 22-12-2008, 06:08 PM   #17 (permalink)
Section Moderator
gopi_vbboy's Avatar
^^ paid.......lol
Old 22-12-2008, 06:32 PM   #18 (permalink)
Wise Old Mouse
mrintech's Avatar
Ok We are Now try out another freeware: http://www.threatfire.com Also no software can beat that paid Kaspersky
- MrinTech :)
mrintech is offline
Old 22-12-2008, 06:39 PM   #19 (permalink)
Deadly Creature Me!
ubersoldat's Avatar
Stop bullying me man . Threatfire, thats crap man. It cannot catch a single spyware or Virus. lol . Nice animated icon though. I shows burning fire when scanning. lol . And if we disable that., it shows an ice cube. Thats nice graphics. I already uninstalled it 2 months ago .
Old 22-12-2008, 06:43 PM   #20 (permalink)
Wise Old Mouse
mrintech's Avatar
Threat fire is Best Free Intrusion Prevention and Detection Utility for Home Use (HIPS): http://www.techsupportalert.com/best-free-hips.htm
- MrinTech :)
mrintech is offline
DVD Drive Ejection Problem stellar Hardware Q&A 13 28-04-2008 08:39 AM
usb drive error Head Banger Mobiles and Tablets 3 25-11-2007 09:59 PM
pen drive error!!! ashwin_ka Software Q&A 5 27-01-2007 10:53 PM
Drive Error metal_mutiah Software Q&A 2 14-09-2006 03:52 PM
*** Serious Drive Error *** vvk_2004 QnA (read only) 8 14-03-2005 09:05 AM
